Set specefics values to the prompt and run other rotine using that values
gustavobernardi
Message 1 of 11
gustavobernardi
Hi Guys, can I specify the required values of a lisp and run it like a AutoCAD command (without coping the code or modifying the original)?
Example:
When I use commands, I can specify previosly and run in silent mode:
(command "._-Layer" "M" "Walls" "C" "6" "" "")
If I try it on a lisp, it doesn't work:
(defun c:POA()
((C:PORTA2D )"A") )
In this case, I have a lisp wich inserts Door blocks and when I use the command, the "A" option insert a Single flush door.
TIA
Replies (10)
Message 2 of 11
john.uhden
If the c:POTRTA2D function takes one argument, then try...
(defun c:POA()
  (C:PORTA2D "A")
However I don't think I have ever seen one build a c: function that takes an argument.  Not that you can't do it, but just that it's kind of abnornal.
Perhaps you should build a PORTA2D function that takes an argument and then...
(defun c:POA()
(PORTA2D "A") )
John F. Uhden
Message 3 of 11
ВeekeeCZ
If possible, use a macro (eg. button), that's the simplest way.
Otherwise see THIS thread.
Message 4 of 11
gustavobernardi
Thank you guys. I think I'll solve it differently. I was just curious to see if it was possible.
Message 5 of 11
scot-65
(defun c:POA() ((C:PORTA2D )"A") )
(defun c:POA ()
(c:PORTA2D)
(command "A")
untested
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 6 of 11
gustavobernardi
Don't worked 😞
I think if it's possible to do I also can use for translating a lisp between languages.
Example: (command "._-layer" "m" "Wall" "c" 6 "") this function don't work on other languages. I know the command "._-layer" is universal, but the suboptions haven't the same key.
Message 7 of 11
Kent1Cooper
Yes, they have -- it's the underscore character.  Try:
(command "._-layer" "_m" "Wall" "_c" 6 "" ""); [and finish the Layer command, as in Post 1]
Just don't also use the period/decimal character with options -- that's only for command names, to force use of the native command in case there might be a customized definition.
Also, you don't need the hyphen before the Layer command name.  That's to suppress the dialog box when used at the Command: line, but inside an AutoLisp (command) function, the non-dialog-box version is always used without  the need for the hyphen.
Kent Cooper, AIA
Message 8 of 11
gustavobernardi
Oh My gosh I think I've tried it any time... Works 🙂
But in the other situation.
Example:
In portuguese I have a door command which structure simplified is like this:
(defun c:PORTA2D()
	(setq op(getkword "\nBloco de porta [Abrir 1 folha / aBrir 2 folhas ]<Abrir 1 folha>"))
		(cond
			((= op nil)(setq portalast (insertdoorA))
			((= op "A")(setq portalast (insertdoorA))
			((= op "B")(setq portalast (insertdoorB))
My imagination is In english make something like this:
(defun c:DOOR2D()
	(setq op(getkword "\nDoor model [Door 1 panel / dooR 2 panel ]<Door 1 panel"))
		(cond
			((= op nil)(c:porta2D "A"))
			((= op "D")(c:porta2D "A"))
			((= op "R")(c:porta2D "B"))
Message 9 of 11
john.uhden
Sorry, but your imagination is a little faulty.
Your c:PORTA2D function is not built to take an argument.
But the c:PORTA2D function looks fine to use as is.
John F. Uhden
Message 10 of 11
gustavobernardi
Yes, the function works fine.
But If I make a Portuguese, an English and a Spanish version it's necessary to recreate basically all the code again.
if have a change in the main code, it's necessary to correct all the instances.
But OK, I will create "engine subroutines" (to do  the job) and "interface subroutines" (for each language). I just wanted to not have to rebuild everything.
Thanks.
Message 11 of 11
john.uhden
There ya go... engine subroutines.  I do that all the time, and only for english.
To lighten your load, you could use language based string symbols...
(cond
  ((= language "english")
    (setq str1 "door") ;; etc.
  ((= language "portuguese")
    (setq str1 "porta") ;; etc.
John F. Uhden
