SET Polyline/Text/Line/Mtext TO ELEVATION OF ZERO
Bin2009
Bin2009
I am looking for a lisp that lets me select or window objects, then if contain any Polyline, Text, Line, Mtext, will set them all to an elevation of zero.
The reason is the drawing original created by civil 3d, but been explore to Autocad drawing, so there some object have different elevation. But we need the elevation for all the object on zero.
Below is an example, I got lines, mtexts, texts high about zero, I hope can have some better way than manually change the elevation for each type of object to 0.
Can someone help me out. thanks in advance!!
Bin
Kent1Cooper
Does the FLATTEN command do what you want?  [In PLAN view in the current Coordinate System, of course.]  If not, describe in detail what is different.
Kent Cooper, AIA
Bin2009
Hello Kent,
Thank for responding, we been told should not use FLATTEN, they said will cost some issue, sometimes lost lines. I don't know why, I will find out the reason.
Bin
paullimapa
Try this:
(defun c:MvToZ (/ ss typ)
 (setq typ "LINE,LWPOLYLINE,*TEXT")
 (princ (strcat "Ojbects Selected must be: " typ))
 (if (setq ss (ssget (list (cons 0 typ))))
    (command "_.CHANGE" ss "" "_P" "_E" "0" "")
 ) ; if
(princ)
Paul Li
IT Specialist
@The Office
Bin2009
Hello Paul,
Your lisp is perfect work for me, I added HATCH and CIRCLE.
Thank you so much!
Bin
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
