Set multileader style
jands
Message 1 of 14
jands
Is it possible to retrieve MLEADERSTYLE of selected Mleader, or/and set current mleaderstyle by selecting the existing mleader in drawing?
Thank you
Replies (13)
Message 2 of 14
ВeekeeCZ
Hello and welcome to the community!
I believe it is. Just try and tell...
(vl-load-com)
(defun c:PickMLStyle ( / en mls)
  (if (and (setq en (car (entsel "\nSelect mleader: ")))
	   (= "MULTILEADER" (cdr (assoc 0 (entget en))))
	   (setq mls (vlax-get (vlax-ename->vla-object en) 'StyleName))
    (command "_.CMLEADERSTYLE" mls))
  (princ (strcat "\nCurrent MLEADERSTYLE: " mls))
  (princ)
Message 3 of 14
jands
Thank you very much, it works!
Happy New Year!
Message 4 of 14
I had a similar question as the OP but have no idea what the above answer is. Is that some sort of code? What is the AutoCAD tool or command to use this?
Message 5 of 14
ВeekeeCZ
It's AutoLISP program, read HERE how to run it.
Message 6 of 14
jands
BeekeeCZ
Your routine worked, but now it doesn't work, returns "error: no function definition: VLAX-ENAME->VLA-OBJECT"
what can be the problem?
Thank you
Message 7 of 14
ВeekeeCZ
@Anonymous wrote:
@ВeekeeCZ
Thank you
first, make sure that following line is a part of your code. You can even try type in this line directly into command line.
(vl-load-com)
If that doesn't work... that's an issue that can lead you to reinstall autocad. Lately, especially with 2017, I remember here were 2-3 threads about this not working. I've found THIS and THIS, you may find some more... Good luck.
Message 8 of 14
jands
Thank you for reply
The  (vl-load-com) line is there.
I'm using AutoCAD 2012 and 2016, so 2017 problems are not applicable for me.
The point is - this routine worked fine in both 2012 & 2016 after I copied it from here.
Looks like i need to reinstall AutoCAD. I will try it next week (too busy now).
Thank you anyway
Message 9 of 14
smallƑish
Is there any option that includes in a code?
Like when I run my lisp need to make my Mleader EP200ML(name of my Mleader) to be current. And later back to user Mleader at the end.
Any tips for that?
Message 10 of 14
Sea-Haven
Did you read post2 the answer is there, use setvar for the leader style.
Message 11 of 14
smallƑish
(setvar "MLEADERSTYLE" EP200ML)
Do you mean like this?
Message 12 of 14
ВeekeeCZ
No, it's
(setvar 'cmleaderstyle "Standard")
Message 13 of 14
smallƑish
Wow, That's perfect!! Thank you.
What's the same for Dimension style?
If we don't have the dim or mleader in the current drawing, is there any option to bring from any previous drawing?
Message 14 of 14
ВeekeeCZ
No, that's a little bit complicated.
(and
  (setq ent (car (entsel "Select dim: ")))
  (or (= "DIMENSION" (cdr (assoc 0 (entget ent))))
      (prompt "\nError: Selected object is not dimension!"))
  (setq obj (vlax-ename->vla-object ent))
  (vlax-property-available-p obj 'StyleName T)
  (setq val (vlax-get-property obj 'StyleName))
  (vl-cmdf "_.-DIMSTYLE" "_R" val)
  (princ (strcat "\nCurrent dimstyle: " val))
If you want to bring some styles from different drawings, make some dwg with it and insert it as a block. Then remove it.
