Set layer polyline by attribute
djurk_haas
djurk_haas
See the lisp code in the attachment.
The code works fine; it changes the layer of the block to the layer wich is given in an attribute in the block itselfs.
Is it possible to (also) change the layer of an "linked" polyline in that block? This polyline is linked through a field in an attribute with an object (See attached jpg).
For example the dwg is also included.
Tanks in advance.
Moshe-A
@djurk_haas  hi,
why don't you move the polyline it inside that block? if you can't do that then your better solution is MATCHPROP
moshe
djurk_haas
Thanks for your reply.
Do you have a lisp code for that solution with match properties?
Moshe-A
@djurk_haas ,
try this lisp,  each run select only 2 objects the block + it's polyline
enjoy
moshe
; Djurk Haas Matchprop
(defun c:DHMP (/ ss i elist ename lay)
 (if (and
       (setq ss (ssget (list '(-4 . "<or")
			   	'(0 . "lwpolyline")
			   	'(-4 . "<and")
			   		'(0 . "insert") '(66 . 1)
			    	'(-4 . "and>")
 			   '(-4 . "or>")
       (= (sslength ss) 2) ; only a block + it's polyline at a time
  (progn
   (setq i -1)
   (repeat (sslength ss)
    (setq elist (entget (setq ename (ssname ss (setq i (1+ i))))))
    (if (eq (strcase (cdr (assoc '0 elist))) "INSERT")
     (progn
      (setq lay (getpropertyvalue ename "HANDLEBLOK")); get layer name
      (command "._chprop" "_si" ss "_layer" lay "")
     ); progn
    ); if
   ); repeat
  ); progn
 ); if
 (princ)
Moshe-A
@djurk_haas
please close this thread and mark it as your solution
thank you
moshe
djurk_haas
Thanks a lot for your code works really fine but it is not what I'm looking for.
I'm trying to get a link between the blockattribute and the 'connected' polyline.
In the attachment is an earlier lsp that put's the area and lenght of the seleted polyline to the specified attributes (VLOEROPP - OMTREK) in the lisp code.
Maybe it is possible to add some code so that this lisp also put the handle, of the selected polyline, into the TAG: HANDLE.
I have the code
(cdr (assoc 5 (entget en)))
that shows the handle of an entity.  So what I want to arcieve is that this output is writing down to the block attribute HANDLE.
Thanks a lot for your help
Moshe-A
@djurk_haas ,
really sorry, up till now i did not fully understand what you want, but of course there is a solution
do you write code activex? cause there is a method (function) called (vla-fieldcode) that returns the field as string
inside is the object id of the polyline - can you continue from here?
moshe
