Set dynamic block property value upon insert
Hello everyone Smiley Happy
Found LM's dynamic block functions but I can't incorporate the simplest task I want to accomplish. The dynamic block has 3 parameters
e.g.
par1 = 5' 4"
par2 = 45
par3 = 1/2"
I need help to insert the block and instantly modify the parameters through lisp. Please help, Thanks in advance! Smiley Happy
(defun c:insertBLK ()
(command ".-insert" "C:\\myblock.dwg" pause 1 "" "")
(princ))
;; Set Dynamic Block Property Value  -  Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun LM:setdynpropvalue ( blk prp val )
    (setq prp (strcase prp))
    (vl-some
       '(lambda ( x )
            (if (= prp (strcase (vla-get-propertyname x)))
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
        (vlax-invoke blk 'getdynamicblockproperties)
;; Get Dynamic Block Property Value  -  Lee Mac
;; Returns the value of a Dynamic Block property (if present)
(defun LM:getdynpropvalue ( blk prp )
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
Shneuph
This worked for one of my dynamic blocks.  No changes to LM's functions:
  (command ".-insert" "detail callout.dwg" pause 1 "" "")
  (LM:setdynpropvalue (vlax-ename->vla-object (entlast)) "Visibility" "Section")
  (princ)
  );defun
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Thanks for the reply Shneuph this will get me going.
Only weird thing is when I set angle parameter to "45" it set it to 58.31 in the drawing.
Shneuph
It needs Radians.. You can use CVUNIT function to easily convert.  You essentially told it the angle to use was (edit: 45 radians which is):2578.31 degrees.  Which when you cancel out all the full circles comes out to 58.31 degrees left over.
I could've NOT guessed that at all! lol
I'm ok just to use radian (0.785398), Thanks again Shneuph!
Shneuph
Always glad to help when I can.
