Set color to "ByBlock" for entities inside blocks
deisajavier
Message 1 of 10
deisajavier
Hi guys, need a little bit of help here.
I want to change color to "ByBlock" for all entities inside of a selected block, including entities on nested blocks and excluding blocks color properties only.
What I mean is color of all blocks (selected one and nested) must remain whitout changes.
It's possible to do something like this?
I've got this code, but only works for a single block and doesnt change nested items.
(defun c:test (/ ss e blk doc)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if
  (setq ss (ssget ":L" '((0 . "INSERT"))))
  (repeat (setq i (sslength ss))
     (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
     (setq blk (vla-item (vla-get-blocks doc) (vla-get-Effectivename e)))
     (vlax-for x blk
       (vla-put-color x 0)
(vla-regen doc acAllViewports)
(princ)
Replies (9)
Message 2 of 10
Moshe-A
check this, did not test it
 (if (setq ss (ssget ":L" '((0 . "INSERT"))))
   (vlax-for x blk
    (if (eq (vla-get-objectname x) "AcDbBlockReference")
     (color->byblock doc x)
     (vla-put-color x 0)
 (princ)
(defun color->byblock (doc x / doc blk)
 (setq blk (vla-item (vla-get-blocks doc) (vla-get-Effectivename x)))
 (vlax-for x blk
   (color->byblock doc x) ; recursion
   (vla-put-color x 0)
Message 3 of 10
deisajavier
Works great!
Thanks Moshe-A
Message 4 of 10
Moshe-A
thank you, happy to hear
don't stop here, give some Likes Smiley Happy
Message 5 of 10
Luke.vansonsbeek
Hi guys,
I really need this code, but first of all, how do i activate this LISP? I am new into those routines. Can someone explain me how i insert this into my Autocad software and how i can use it?
Message 6 of 10
Kent1Cooper
Lee Mac has a good tutorial about that, >here<.
The command name is what immediately follows the c: at the top, so you should probably change that from "test" to something more meaningful.
Kent Cooper, AIA
Message 7 of 10
3dwannab
Here's a modified EditBlock.lsp by gileCAD, so ALL credit goes to him. The main thing here is that it changes blocks inside of blocks and works with dynamic blocks.
NOTES:
- Removed the UI so the command runs with the settings that I use the most.
WHAT THE MODIFIED VERSION DOES:
- Set the layer to 0
- Sets the colour, linetye, lineweight and transparency of everything to "ByBlock"
- Sets the line type scale to 1.
- Sets the units of the blocks to millimetres.
- Removed the vla-put-PlotStyleName function.
- This works with nested blocks as per Gilles' original code.
- This works with dynamic blocks as per the original code by Gilles because otherwise resetting a dynamic block that was changed reverts to its original.
MODE:
- There are 4 main modes to choose from.
'ByBlock' 'ByLayer' 'ByLayer0LTScale1' and 'LTScale1' which can be run with the same commands.
Method "ByLayer"
- Transparency set to "ByLayer"
- Layer is set to "0"
- Colour is set to ByLayer
- Line type is set to "ByLayer"
- Line weight is se to ByLayer
- Line type scale is set to 1
Method "ByBlock"
- Transparency set to "ByBlock"
- Colour is set to ByBlock
- Line type is set to "ByBlock"
- Line weight is se to ByBlock
Method "ByLayer0LTScale1"
Method "LTScale1"
Note: You can easily add to this if you like.
The processAllSwitch switch used in the BKByBlockKeepHatch command:
- Will set all to byblock like the method "ByBlock", except that it will not process hatches.
CREDIT GO TO GILLIES
- Full credit goes to Gillies for the original script. I just butchered it to make it work without a dialog box.
Message 8 of 10
andrea_ricciNMVSG
thank you for your lisp.
How do avoid the unit change?
Is there also a way to set the block parameters "Scale Uniformly" → yes and "Allow Exploding" → no?
Thank you very much
Message 9 of 10
3dwannab
;; Removed unit change
;  (if (< 16.1 (read (substr (getvar "acadver") 1 4)))  ;_ Unit?
;    (if (/= (setq i_unt (vla-get-units bloc)) unt)
;      (vla-put-Units bloc 4) ;; Millimeters
Add ; to each of the lines like the above..
For exploding, use the attached and the scale lisp too.
Message 10 of 10
andrea_ricciNMVSG
Thank you so much!
