Set a page setup current with lsp
cslatteryAXGRE
cslatteryAXGRE
I see this is talked about quite a bit. But I would like to be able to apply a page setup to the active layout tab with lsp. I have this for importing the page setup that I want, but I cannot seems to get it to be applied to my current layout without opening the page setup manager dialog box.
(defun C:3624PageSetup ()
(command "._-PSETUPIN" "X:/XX/Page Setups.dwg" "3624 PDF")
LDShaw
Try this.
(command "._-PSETUPIN" "x:\\xx\\Page Setups.dwg" "3624 PDF")
(vlax-for x
(vla-get-plotconfigurations
(setq d (vla-get-activedocument (vlax-get-acad-object))))
(if (= (strcase "3624 PDF") (strcase (vla-get-name x)))
(vl-catch-all-apply 'vla-copyfrom (list (vla-get-activelayout d) x))
Help page
Baker_ADG
(defun C:22x34 ()
(vl-load-com)
;(DelPgSetups)
(setq pl (vla-get-PlotConfigurations
(vlax-for item pl
(vlax-invoke-method item 'delete)
(command "._-PSETUPIN" "c:/path to dwg-dwt/drawing.dwt" "34x22 PDF")
(defun SetCurrentPageSetup (doc pcname / layout PlotConfig)
  (setq	doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq layout (vla-get-activelayout doc))
  (setq PlotConfig (vl-catch-all-apply
		     'vla-item
		     (list
			 doc
		       pcname
  (if (not (vl-catch-all-error-p PlotConfig))
    (vla-copyfrom layout PlotConfig)
(SetCurrentPageSetup <AcadDocument> <PageSetupName>)
(SetCurrentPageSetup (vla-get-activedocument (vlax-get-acad-object)) "34x22 PDF")
  (setq	aDoc  (vla-get-activedocument (vlax-get-acad-object))
	Layts (vla-get-layouts aDoc)
	clyt  (vla-get-activelayout aDoc)
  (foreach
	    itm
	       (vl-remove (vla-get-name clyt) (layoutlist))
    (vla-copyfrom (vla-item Layts itm) clyt)
this is what i used in the past.
Jon Baker | Land Development & Infrastructure Design Manager
Alignment Design Group | Denver | Colorado
Civil 3D 2025 | Windows 11
LDShaw
Just for fun if it does not find the setup it will tell you what page setups are in the dwg.
(command "._-PSETUPIN" "x:\\xx\\trash1.dwg" "3624 PDF")
(defun lm:psetup2tab (/ d found setup-list)
(setq found nil) ; Initialize a variable to track if the page setup is found
(setq setup-list "") ; Initialize a string to collect page setup names
(vlax-for x (vla-get-plotconfigurations
(setq setup-list (strcat setup-list (vla-get-name x) "\n")) ; Append each page setup name to setup-list
(progn
(setq found T) ; Set found to true if the page setup is found
(if (not found) ; If the page setup is not found, display an alert
(alert (strcat "The page setup '3624 PDF' was not found.\nAvailable page setups:\n" setup-list))
(lm:psetup2tab)
