Serial number
Serial number
Message 1 of 18
Serial number
I'm wondering if there is a command in autolisp that allows you to get a serial number (eg hard disk serial number or similar)?
Replies (17)
Message 2 of 18
hak_vz
https://www.cadtutor.net/forum/topic/9848-how-to-get-serial-number-of-hard-drive-by-lisp/
Miljenko Hatlak
Message 3 of 18
Kent1Cooper
Also, put something like "drive serial number" into the Search window in this Forum, and you'll find several threads on the subject.
Kent Cooper, AIA
Message 4 of 18
I searched a lot of examples on this topic, but I did not find any correct examples.  Can you write me one example that works? Need only one variable to store some stable serial number in?
Message 5 of 18
Sea-Haven
; drive type 1 is a usb 2 hard disk
(defun UsbDriveSerialNumber ( / fso dr)
  (setq fso (vlax-create-object "Scripting.FileSystemObject"))
  (vlax-for d (vlax-get fso 'Drives)
    (if
	  (= (Vlax-get  d 'DriveType) 2)
      (setq dr (cons (list (vla-get-path d) (vla-get-SerialNumber d)) dr)
  (vlax-release-object fso)
  (reverse dr)
(UsbDriveSerialNumber)
Apologise to original author not sure where I got this from
Message 6 of 18
hak_vz
Try this
(defun DiskDriveSerial (/ WMI Serv DiskD item prop ser)
 (vl-load-com)
 ;; Lee Mac  ~  13.05.10
 (setq WMI    (vlax-create-object "WbemScripting.SWbemLocator")
       Serv   (vlax-invoke WMI  'ConnectServer nil nil nil nil nil nil nil nil)
       DiskD  (vlax-invoke Serv 'ExecQuery "Select SerialNumber from Win32_DiskDrive"))
 (vlax-for item DiskD
   (vlax-for prop (vlax-get item 'Properties_)
     (if (eq "SerialNumber" (vlax-get prop 'Name))
       (setq ser (vlax-get prop 'Value))
 (mapcar 'vlax-release-object (list DiskD Serv wmi))
 ser)
Miljenko Hatlak
Message 7 of 18
Neither works for me. I don't understand why.
Message 8 of 18
hak_vz
@Anonymous  Which version of autocad  and operating system you use?
Miljenko Hatlak
Message 9 of 18
Autocad 2014 and Windows 10
Message 10 of 18
hak_vz
What you receive when you run  in system console after you load lisp?
(DiskDriveSerial)
or separately
(setq WMI(vlax-create-object "WbemScripting.SWbemLocator")))
(setq Serv   (vlax-invoke WMI  'ConnectServer nil nil nil nil nil nil nil nil))
(setq DiskD  (vlax-invoke Serv 'ExecQuery "Select SerialNumber from Win32_DiskDrive"))
This should work fine with your software
Miljenko Hatlak
Message 11 of 18
Great, it works. I'm wondering how to use that serial number as a license key now? How to make every time you start AutoCAD a request to enter a license key?
Message 12 of 18
hak_vz
Check this link
Miljenko Hatlak
Message 13 of 18
I was thinking of some code inside .lsp that would ask for a serial key. Also is there anything free?
Message 14 of 18
Sea-Haven
Ok make a fas when happy with lisp,
run get setserial id as suggested.
(if (= "1233456" serialnum)(princ "ok")
(progn (alert "Ok I know you have pirated the software you !@#$%\n pay your money to use it")(exit))
Ok now for the lesson how do I put in 25 modules its super easy if your old like me and take advantage of a DOS function, you write the lisp serial.lsp which has the get disk id and the disk number.
Then its simple DOS from CMD
Copy serial.lsp+lisp1.lsp c:\serialisp\lisp1
repeat use a batch file.
The tricky bit is how do you get the end users serial number ? Send him a Fas and they email the number to you.
You can multi lisp to individual fas via a lisp program or batch into a vlx.
Message 15 of 18
hak_vz
@AnonymousIt is as simple as @Sea-Haven stated. Proposed code works under same principles, with probably some aditional security options. Its help actually shows how to do as a software developer you should be able to write it down.
If someone is so desperate, he can change disk serial number (google it), so you have to think about way to do it. What if user reinstalls payed software to new computer....?
Miljenko Hatlak
Message 16 of 18
Sea-Haven
I work on the 99% rule that people have no idea of how to break the security code.
There are other ways like pinging a web site server and comparing a disk id etc.
Re installs to new pc has to know about using disk ID. When asking for ID number scramble etc or convert to hex. Even use characters in excess of assci code 127 in a emailed string so will not appear visible at 1st. Can auto email from lisp.
I have been contacted "the software is not working" it turns out the guy was trying to install on buddy's computer and abrupt "No" pay please.
Message 17 of 18
i am re activate auotocad2020.but the licence expire and i don't  no serail number and product key .so please inform me any one where is it and how is it find out.
Message 18 of 18
serial number for product key 001I1 in autocad 2017
