Sending mail via utolisp that includes both subject and body
jakob_holmquist
Message 1 of 9
jakob_holmquist
 In this website it shows how to create a mail to a specific mail that includes but a subject and a body in the email by using HTML, and it works perfectly. When using basically the same code in autocad like this:
(command "start" "mailto:test@example.com?subject=TestSubject&body=TestBody!")
a mail is created with the correct receiver, correct subject, but the body is empty.
If I reverse the order of body and subject in the command like this
(command "start" "mailto:test@example.com?body=TestBody!&subject=TestSubject!")
then the body is included, but not the subject.
How can I include both subject and body at the same time?
I have searched for this and found solutions using visual lisp, but all those force the mail to be either closed or sent before you can do anything with either outlook or AutoCAD, and I want to avoid that functionality. If there is a way to make the visual lisp solution to not hijack both AutoCAD and Outlook that would work also.
Replies (8)
Message 2 of 9
paullimapa
https://superuser.com/questions/914365/mailto-command-line-not-able-to-set-additional-parameters
(command "start" "mailto:test@example.com?subject=TestSubject^&body=TestBody!")
Paul Li
IT Specialist
@The Office
Message 3 of 9
paullimapa
**modified**
and for spaces use %20:
(command "start" "mailto:test@example.com?subject=Test%20Subject^&body=Test%20Body!")
Paul Li
IT Specialist
@The Office
Message 4 of 9
john.uhden
@paullimapa ,
Might there be any way to do that using Gmail?
John F. Uhden
Message 5 of 9
paullimapa
If your default email client app is configured to send/receive email with your gmail account then yes.
Paul Li
IT Specialist
@The Office
Message 6 of 9
john.uhden
@paullimapa ,
Thanks.  I'll have to figure out how to do that.
John F. Uhden
Message 7 of 9
paullimapa
For example, I use Outlook as my desktop default email client.
Then I follow these instructions to setup my Outlook to connect to my gmail:
https://support.microsoft.com/en-us/office/set-up-gmail-accounts-46274497-95ea-4a7d-9651-d246aa63eb5...
Paul Li
IT Specialist
@The Office
Message 8 of 9
jakob_holmquist
Thank you, this was exactly what I was looking for! 🙂
Message 9 of 9
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
