Send Backwards all hatches in a block
zafera5VK85
zafera5VK85
Hello Form,
I'm having difficulties to send all hatches to backwards in a block. Anyway to solve this issue?
Best regards
Victor.
LDShaw
Here is a lisp that removes hatches from a dwg.
(defun c:dlhatch (/ adoc)
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (vlax-for blk_def (vla-get-blocks adoc)
    (if (equal (vla-get-isxref blk_def) :vlax-false)
      (vlax-for ent blk_def
        (if (= (vla-get-objectname ent) "AcDbHatch")
          (vl-catch-all-apply
            (function
              (lambda ()
                (vla-erase ent)
                ) ;_ end of lambda
              ) ;_ end of function
            ) ;_ end of vl-catch-all-apply
          ) ;_ end of if
        ) ;_ end of vlax-for
      ) ;_ end of if
  (vla-endundomark adoc)
  (princ)
Untested but maybe this?
(defun c:foohatch (/ adoc)
          (vl-catch-all-apply
            (function
              (lambda ()
                (vla-sendtoback ent)
              ) ;_ end of lambda
        ) ;_ end of if
    ) ;_ end of if
  (princ)
Just changed the erase to a sendback
Sorry I just tried this. It does not work. My best guess is it has something to do with the pointing system when blocks are created.
pendean
Community Legend
Community Legend
@zafera5VK85 wrote:
...I'm having difficulties to send all hatches to backwards in a block. Anyway to solve this issue? ...
it appears your attribute and your hatch are one and the same color, nothing more.
Same with the "table" outline.
Your issue is not draworder, but color
You need to fix your blocks' content to be different from each other, not all the same.
