SELECTIONANNODISPLAY tool palette button
ckeesGF9JG
ckeesGF9JG
Hi I want to create a tool palette button that toggles SELECTIONANNODISPLAY between <1> and <0>. Can someone help me the structure the command string so that it toggles the opposite of what is current?
natasha.l
Hello @ckeesGF9JG
I believe you want to customize a command, if it is available you can make your changes in the Customize User Interface (CUI) Editor.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
SeeMSixty7
Create your button and use the following for the command macro
^C^C(if (= 1 (getvar "SELECTIONANNODISPLAY")) (setvar "SELECTIONANNODISPLAY" 0) (setvar "SELECTIONANNODISPLAY" 1))
Good luck,
Crass
Hello. Thanks for the response. Is this a candidate for creating a conditional expression?
I tried this...
^C^C_$M=SELECTIONANNODISPLAY (-,1,$(getvar,fillmode))
but it didn't seem to work.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
cadffm
^Q'_.SETVAR;SELECTIONANNODISPLAY;$M=$(-,1,$(getvar,SELECTIONANNODISPLAY))
^Q'_.SELECTIONANNODISPLAY;$M=$(-,1,$(getvar,SELECTIONANNODISPLAY))
Sebastian
