Selection set
Selection set
Automohan
Selection set
Automohan
When I Load selection 3 times I didn't change anything in AutoCAD but why these Selection set "names" are changing......
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
dlanorh
If you run it three times you'll get three different selection sets. AutoCAD doesn't know they're all the same.
I am not one of the robots you're looking for
Ajilal.Vijayan
For each time when you load this code, AutoCAD creates a new selection set with an unique id.
The id will change each time for the selection, but you can refer to your local variable 'sel1' to get the selection.
