selection set using existing polygon
islam.a.hamza95
Message 1 of 10
islam.a.hamza95
Hi all,
sorry if this question seems to be silly, i am beginner at autolisp
I want to create  selection set from an existing polyline that the user picks.  The selection set should select everything inside of the closed polyline.
and i tried all arguments I know in ssget function and it didn't work for me.
can anyone help me ?
Replies (9)
Message 2 of 10
ВeekeeCZ
If your polygon is lwpolyline without arc segments, you can use the attachment. That's probably not mine but looks good as an example of how to approach such a task.
Message 3 of 10
calderg1000
Regards  @islam.a.hamza95
For what you require there are many examples in the forums. But if you want to learn, to start with the ssget method, you can use the following:
;;;1. Select the polyline and apply any method to get the list of points of its vertices
(setq p_list(entget(car(entsel"\nSelect the LwPolyline: "))))
;;;2. Apply the SSGET method, Polygon window. To select objects that are inside the selected polygon
(setq s (sssetfirst nil (ssget "_wp" (list p_list))))
 To learn, try first, if you can't, ask for help..., here we are happy to help
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 4 of 10
Sea-Haven
Sometimes also want "CP".
For pline pts
(setq plent (entsel "\nPick pline"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(princ co-ord)
Note if you have arcs it becomes more complicated and need to use facets around the arcs.
Message 5 of 10
pbejse
@islam.a.hamza95 wrote:
...and i tried all arguments I know in ssget function and it didn't work for me
CP
Crossing polygon selection; all objects crossing and inside of the specified polygon.
syntax is
(ssget "_CP"  [pt-list] [filter-list])
You need to retrieve the vertices of the selected polyline.
Note that objects visible in the drawing area at the time of selection  will be selected
HTH
Message 6 of 10
Kent1Cooper
That feeds the entire entity data list for the Polyline into the (ssget) function for a window polygon, but it can't take that -- it needs a list of points only.
Command: (setq s (sssetfirst nil (ssget "_wp" (list p_list))))
; error: bad list of points
Kent Cooper, AIA
Message 7 of 10
calderg1000
Dear @Kent1Cooper
It's true, although my intention was just to give the OP an idea, to start. But surely I should have been much more explicit. Here is the complete code that allows the selection of objects inside a polygon (Lwpolyline)
(defun c:SelW (/ p_list p_coord)
  (setq p_list (entget (car (entsel "\nSelect the LwPolyline: "))))
  (if (setq
        p_coord (mapcar 'cdr
                        (vl-remove-if-not '(lambda (x) (= (car x) 10)) p_list)
    (sssetfirst nil (ssget "_wp" p_coord))
Carlos Calderon G
Message 8 of 10
hosneyalaa
Hi
Please- maybe get further help,
upload such sample.dwg
Message 9 of 10
_Tharwat
What's if a user missed to select any object, what would happen ?
Of course an error message will be printed on command line and what's more it will break up the routine.
Again suppose a user picked another object which is does not have DXF 10 , what will happen ?
I will leave this answer for you.
Besides all of the above, the object(s) must be visible in current screen limits as @pbejse announced earlier. 😉
Message 10 of 10
Sea-Haven
To make sure pick a pline can use this idea use ssget with E: option but also (0 . "LWPOLYLINE") as a filter it will then ignore a pick wrong object. You then use (ssname ss 0) to get pline object back out of the selection. Wrap it in a while to make sure correct pick.
(setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))) I selected a line
Select entities: nil
(setq ss  (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))) I selected a pline
Select entities:<Selection set: 0000000068F17D70>
(setq ent (entget  (ssname ss 0)))
((-1 . <Entity name: 68f15230>) (0 . "LWPOLYLINE") (5 . "11C49") (330 . <Entity name: 3eecdcb0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "DEFAULT") (370 . -1) (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.8 -9.8) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 1.93319257450986 -2.89233218885884) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 11.2740839009524 -3.94482885279246) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0))
