Selecting objects by layer property
I am trying to create a lisp that will select all objects on all layers whos linetype property is not equal to continuous. My ultimate goal is to select all lines and turn them to layer 0 but keep the original line type.
For example:
   all lines are set to linetype: by layer
layer list:
  lay1   linetype: continuous
  lay2   linetype: continuous
  lay3   linetype: continuous
  lay4   linetype: hidden2
  lay5   linetype: hidden2
  lay6   linetype: phantom
I want to select everything on lay4, lay5, and lay6 and change the linetype overwrite from "bylayer" to "hidden2" so that when I change them over to layer 0, the line will still look hidden2.
Thank you for your help
Have a great day!!!
Kent1Cooper
Welcome to the Forums!
This kind of thing comes up here now and then, in fact a couple of times quite recently, for example here.  What you'll find there may be more extensive than you need [designed to do everything in the drawing, and there are links to things to do everything in Block definitions], but could be pared down to do a little less, if you prefer.
Kent Cooper, AIA
Thank you!! This pointed me in the corect direction. I appologize for the delayed reply. I appreciate your help.
Have a great week!!!!
