Selecting an object from it's entity name
Ok. Seems what I'm doing isn't very common.
Short question: Why does this command give an error? How do I make it work?
(ssget "_X" (list (cons -1 "29b079e26e0" ) ) )
This one doesn't work either:
(ssget "_X" (list (cons -1 "<Entity name: 29b079e26e0>" ) ) )
Long question:
I wrote a script to tabulate entities in a couple of hundreds of dwgs along with their attributes. Then I did some post-processing on the excel table to identify objects with errors in their attributes. Now I need to go fix them.
Basically, I've got a huge table with two columns. How can I get AutoCad to select an object with it's entity name?
DWG                | Entity Name
DWG001.dwg | 29b079e26e0
DWG001.dwg | 29b079db290
DWG002.dwg | 29b149a3e10
DWG002.dwg | 29b149a3dd0
DWG003.dwg | 29b14aeaa30
cadffm
Because your cons creates a dottedpair of 1 and a string, but an entity list want a ename (datatype!).
You can not convert a strin to an ename, sorry.
And enames in excel are not senseful.
You have to use the HANDLE per file as "Objectid".
Handles are stored in dwgs and unique (per file).
Enames are not stored in dwg and next time tge object generate another ename.
Sebastian
Kent1Cooper
Unfortunately, though entity names look like  text on-screen, they are not text strings.  You can't copy the text "look" and then bring it back in as text, and get the entity.
Use their handles instead [in the (assoc 5) entry in entity data], which are  text strings representing hexadecimal numbers, and the (handent) AutoLisp function to get access to the entities from them.
The other benefit of using handles instead of entity names is that they are permanent.  The entity name of an entity can sometimes be different after you close the drawing and open it again.
Kent Cooper, AIA
Sorry for the dumb question. Thought Entity names were consistent across sessions. If I understand correctly, then the "handle name", code 5, would be the data I want to save, right?
Then this should work... Am I right?
(ssget "_X" (list (cons 5 "ADF3E" ) ) )
Actually no. If anyone else is interested, the correct command is:
(handent "ADF3E")
Thanks for replying guys.
