SELECT THE EDGE OF ANY CYLINDER AND GET THE RADIUS AND DIRECTION IT IS GOING
cadking2k5
cadking2k5
I want to be able to select Edge 1 and 2 like you do in the copy edge command and be able to get the cylinders radius and direction it is going. Any cylinder a new drawn one on edit on or
Kent1Cooper
Just some starting thoughts....
Applying (osnap) to the selection point with NEArest and CENter modes will give you two points, the distance between which will give you the radius.
If you don't select the edge at  a quadrant point [your pointer to Edge 2 looks at least very close to one], then applying (osnap) with QUAdrant mode would give you a third point, which along with the NEA/CEN points would define a plane, and the direction the cylinder is headed will be a normal from that plane.
The part I can't picture how to do is to determine in which of the two possible directions  the Solid extends from that defined plane.
Kent Cooper, AIA
cadking2k5
Sorry I didn't make it clear but this is in customiztion autolisp
Kent1Cooper
Certainly.  It can do all that I described [that's why I wrote "Applying (osnap)" with the parentheses -- (osnap) is an AutoLisp function]:
(setq
  pick (cadr (entsel "\nPick cylinder edge: "))
  nea (osnap pick "_nea")
  ctr (osnap pick "_cen")
  qua (osnap pick "_qua")
  rad (distance nea ctr)
The 'rad' variable is the radius you're after.  The 'nea' and 'ctr' and 'qua' variables define the plane of the cylinder end face, provided the 'nea' and 'qua' are not at the same location.  Those can be converted into an axis direction, but a big challenge is whether it can be determined in which of the two directions along that axis the cylinder is "aimed."  Another question:  in what format would you want the "direction" expressed -- as a unit vector, similar to the extrusion direction [210-code] in entity data?
Kent Cooper, AIA
_gile
You can try something like this:
(if (setq cyl (car (entsel "\nSelect cylinder: ")))
  (if (= (cdr (assoc 0 (entget cyl))) "3DSOLID")
    (if (= (getpropertyvalue cyl "SolidType") "Cylinder")
      (alert (strcat "Height: "
                     (rtos (getpropertyvalue cyl "Height"))
                     "\nRadius: "
                     (rtos (getpropertyvalue cyl "Radius"))
      (alert "Selected solid is not a cylinder")
    (alert "Selected object is not a 3D solid")
  (alert "Nothing selected")
Gilles Chanteau
GileCAD
GitHub
Kent1Cooper
(if (= (getpropertyvalue cyl "SolidType") "Cylinder") ....
Message 1 on this thread doesn't say one way or another, but from >this on another thread< I assume that it's showing compound [UNION'ed] 3D Solids, not primitives that could be detected in that way.
[This is a good reason for not posting essentially the same question in more than one place....]
Kent Cooper, AIA
