Select the block take the value of the attribute and enter another attribute as FIELD
Message 1 of 8
Select the block, take the attribute value and enter another attribute as FIELD
Does anyone have any sub-function or function that I select the BLOCK ask for the tag value and insert as field in another block.
example:
(setq ent (car (entsel "Select block_01")))
;; {get ATT1 tag attribute value} ;; I don't know how to do it
(setq set_ (car (entsel "Select block_02"))
;; {set the field value in the ATT4 tag} ;; I don't know how to do it
Explain to me how I can do it is already of great help !!!
Replies (7)
Message 2 of 8
ronjonp
Use NENTSEL to get the attributes. No error checking but here's a quick example.
(defun c:foo (/ ent ent2)
  ;; RJP » 2020-10-13
  (if (and (setq ent (car (nentsel "Select block_01")))
	   (setq ent2 (car (nentsel "Select block_02")))
    (vla-put-textstring
      (vlax-ename->vla-object ent2)
      (strcat "%<\\AcObjProp Object(%<\\_ObjId "
	      (itoa (vla-get-objectid (vlax-ename->vla-object ent)))
	      " >%).TextString>%"
  (princ)
*You might have to regen to see the result.
Message 3 of 8
pbejse
HYG
(defun c:NowYouKnow ( / ent ObjetID set_)
(if
  (and
    	;;	Select the Source Attribute	;;;
	(setq ObjetID (itoa (vla-get-objectid (vlax-ename->vla-object ent))))
	;;;	Select the Target Attribute	;;;
	(setq set_ (car (nentsel "Select block_02")))
 (vla-put-textstring (vlax-ename->vla-object set_)
                    (strcat
                        ObjetID
                        ">%).TextString>%"
  (princ)
HTH
EDIT: Oops, too slow 🙂
Message 4 of 8
thanks @pbejse  and @ronjonp
That's almost! but it would be to select the block (entsel) not the attribute (nentsel).
Message 5 of 8
ronjonp
How do you choose what attribute to map it to? You have two blocks with 4 distinct tag names.
Does this little snippet shed any light?
(if (and (setq e (car (entsel)))
	 (vlax-property-available-p (vlax-ename->vla-object e) 'hasattributes)
  (setq atts (vlax-invoke (vlax-ename->vla-object e) 'getattributes))
Message 6 of 8
pbejse
Not sure if this is what you need
(defun c:NowYouKnow ( / GetSetValue mySourceTag myTargetTag source mySourceID TargetBlocks)
(defun GetSetValue (e od tg)
	       (Vl-some '(lambda (v)
			    (cond
			       ((and
				(setq f (eq (vla-get-tagstring v) tg) ) od)
			        (vla-put-textstring v
					    (strcat "%<\\AcObjProp Object(%<\\_ObjId "  od
		                        		">%).TextString>%")
	                    		) tg
			         ( f  (itoa (vla-get-objectid v))
		    (Vlax-invoke e 'GetAttributes)
(setq mySourceTag "ATT1"
      myTargetTag "ATT4")
(if
  (and
    (princ "\nSelect source block")
    (setq source (ssget "_+.:S:E" '((0 . "INSERT")(66 . 1))))
    (setq mySourceID (GetSetValue (vlax-ename->vla-object (ssname source 0)) nil mySourceTag))
    (princ "\nSelect target block(s)")
    (Setq TargetBlocks 	(ssget "_:L" '((0 . "INSERT")(66 . 1))))
  (repeat (setq i (sslength TargetBlocks))
    	(setq et (vlax-ename->vla-object (ssname TargetBlocks (setq i (1- i)))))
    	(GetSetValue et mySourceID myTargetTag)
    	(command "_updatefield" (ssname TargetBlocks i) "")
  (princ)
You  get to select the source block, as long as it has the tag "ATT1" it will continue to prompt for target block(s)
If any of those selected has "ATT4" it will be processsed.
Message 7 of 8
@pbejse  that's right, thank you very much!
Message 8 of 8
pbejse
Good for you.
Happy to help.
