Select specific data - HELP!
Message 1 of 1
I am desperate! I will make this as short as I can. I have a routine I use to add/edit xdata (attached lisp). This works fine. I also have a little routine that will select all blocks with xdata, return twice (just to end selection) then freeze previous. What I need, badly, is a routine that will also select the xdata text associated with the symbol. The only text, from the attached routine, that would be visible would be; refdesignator, visfield1, visfield2, visfield3, zone, info1, info2 and/or info3. I may have one to all texts associated with the symbol. All I need to do is select the associated text with the selection of the blocks but I do not know how to call this text. I would be more than just grateful if someone could help. If you would like, respond with e-mail address and I can give further information if needed.
Many thanks in advance.
D
Replies (0)
