I have been lurking these forms for bits of lisp code for a while now and have come up with a series of LSP files that can do the job decently well.
I will begin by defining my task and current process (in case you can think of shortcuts), I will then give the code I have that works in its own way. Select blocks in specific areas (denoted by a thick PLINE) then use BCOUNT or LISP function to export BCOUNT to excel, then sort and filter multiple CAD BCOUNTS into a master excel doc.
Areas for improvement:
Priority 1: Filter BCOUNTS (by name) (some may not need to be exported and are irrelevant)
Priority 2: combine multiple BCOUNTS into easy to sort format (like have missing values spit out 0)
OPTION 1:
_Function for setting up for text selection_
attached: OutlineLWpolyline.lsp
_Function for selecting text for BCOUNT(this and previous code together is an awful lot of work to select for multiple sections)_
attached: BCOUNTPL.lsp
Then I copy and paste into the CMD window into Excel.
_________________________________________________________________
OPTION 2:
The other method (quicker)
Select area(s) with cursor, Shift select areas not wanted,
_Function to extract to excel_
BLOCKS2EXCEL.LSP (just need block name and quantity (attributes would be nice but not needed)
If possible I would like code that grabs blocks from inside multiple PLINE widths (found code that grabs everything touching the PLINE but not inside the width) and exports it into a excel file. The icing on the cake for me would be some sort of name filtering in a bcount like lisp command sorta like what you can do with attribute extraction text file.
Thank you so much for reading and I look forward to reading through the responses.
