Select objects, change layer, turn off other layers and recolor
etilley327KA
Message 1 of 8
etilley327KA
ACAD 2022
I do this same process tons of times in a day and I'm looking for a way to speed up the process, any help would be very much appreciated.
Not sure how to write this LISP, but I'm obviously doing something wrong. Ultimately, I'm trying to start LISP, select multiple objects hit enter and then it changes the selected objects to layer "00FORM", double the object size, turn off another layer and change the color of another layer. The current coding doesn't even touch resizing at the moment, but if I could get everything else to work would be great.
(defun c:FDERT (SELECT OBJECTS, CHANGE OBJECTS LAYER, TURN OFF LAYER / A)
(princ "\nSelect Points ")
(setq A (ssget))
(vl-cmdf "._change" A "" "_p" "_la" "OOFORM")
(command "_LAYER" "_OFF" "SHOT" "_F" "SHOT"
"_C" "255" "0ELEV,PNTELEV" "")
(princ)
Replies (7)
Message 2 of 8
ВeekeeCZ
@etilley327KA wrote:
ACAD 2022
(defun c:FDERT (SELECT OBJECTS, CHANGE OBJECTS LAYER, TURN OFF LAYER / A)  ; place your note here, behind a semicolon
(setq A (ssget))
(princ)
This is the main issue. That's not a space for a comment.
Message 3 of 8
Kent1Cooper
(defun c:FDERT (/ A); (SELECT OBJECTS, CHANGE OBJECTS LAYER, TURN OFF LAYER / A)
(setq A (ssget))
(vl-cmdf "._change" A "" "_p" "_la" "OOFORM" ""); <-- and finish the CHANGE command
(princ)
Kent Cooper, AIA
Message 4 of 8
etilley327KA
Sweet! That seemed to be it, thanks. Any ideas on how I could add resizing to my LISP?
Message 5 of 8
Kent1Cooper
That can be done, if you have a way of determining a base point around which to Scale them.  You can combine multiple commands in one (command) function [I don't see any reason to use both (vl-cmdf) and (command):
(defun c:FDERT (/ A); SELECT OBJECTS, CHANGE OBJECTS LAYER, TURN OFF LAYER
  (setq A (ssget))
  (command
    "_.scale" A "" {Your scaling base point} 2
    "_LAYER" "_OFF" "SHOT" "_F" "SHOT" "_C" "255" "0ELEV,PNTELEV" ""
  (princ)
Kent Cooper, AIA
Message 6 of 8
etilley327KA
Thanks so much, how can it pull the base point data for each object.
Message 7 of 8
Kent1Cooper
You want each object doubled in size separately, not as a group?  You still need to have a base point for each.  If you want them all Scaled about the midpoint of their individual bounding boxes [extents], so they kind of stay where they are, you can use ScaleAboutCenters.lsp with its SAC command, >here<.  I suppose your other operations could be incorporated into a modification of that.
Kent Cooper, AIA
Message 8 of 8
etilley327KA
Thanks, that's what I'm currently looking at. I'm trying to combine them together so that the data is pulled only once. Not having much luck with it so far.
