select multiple objects
W_T_
W_T_
This LISP,
It can only select one object.
I hope it can select multiple objects
(defun c:Erase-All-R ()
 (command "_.ERASE" "_ALL" "_R")
 (princ "\nPlease select objects and press Enter.")
 (command pause )
 (command "")
 (princ)
paullimapa
; (command pause )
  (while (> (getvar "CMDACTIVE") 0)(vl-cmdf pause))
; (command "")
 (princ)
Paul Li
IT Specialist
@The Office
Kent1Cooper
This is all you really need:
(defun C:EAB () (command-s "_.erase" "_all" "_remove") (prin1))
The command will supply its own prompt for removing objects from the selection, so you don't need to write that out.
[EAB stands for Erase All But -- change it to whatever you prefer.]
Kent Cooper, AIA
W_T_
いつもありがとうございます。
paullimapa
Glad to have helped….cheers!!!
Paul Li
IT Specialist
@The Office
