select multileader by style
Paul.GrafPZAZ7
Paul.GrafPZAZ7
I am trying to write a routine that will select all the multileaders in a drawing by a stylename and move them to a new layer.
I am having problems getting the program to select a multileader by a specific style. It reports that there are no multileader in the drawing with the style name of "AEC_KN_Keynotes".
Here is a screen shoot of the multileader:
(defun c:sml ( / styleEnt ss )
(setq styleEnt (tblobjname "mleaderstyle" "AEC_AC_Keynotes"))
(if styleEnt
(progn
(setq ss (ssget "X" (list '(0 . "MULTILEADER") (cons 340 styleEnt) '(67 . 1))))
(if ss
(progn
(sssetfirst nil ss)
(princ (strcat "\nSuccess: Selected " (itoa (sslength ss)) " Multileaders."))
(princ "\nNotice: No Multileaders found with style 'AEC_AC_Keynotes' in Paper Space.")
(princ "\nError: The MLeader style 'AEC_AC_Keynotes' does not exist in this drawing.")
(princ)
Attached is my drawing & lisp file. Any help would be appreciated.
Paul
komondormrex
try to ssget all mleaders first, then filter out those that don't use the requested style.
Paul.GrafPZAZ7
I just got this to work:
(defun c:sml2 ( / ss i ent obj styleName selectList )
(vl-load-com)
;; 1. Select all Multileaders strictly in Paper Space (Layouts)
(setq ss (ssget "X" '((0 . "MULTILEADER") (67 . 1))))
(if ss
(progn
;; Create an empty selection set to hold matches
(setq selectList (ssadd))
(setq i 0)
;; 2. Loop through each MLeader and check its Style Name property
(repeat (sslength ss)
(setq ent (ssname ss i))
(setq obj (vlax-ename->vla-object ent))
(setq styleName (vlax-get-property obj 'StyleName))
;; If it matches our target style, add it to the final selection list
(if (= (strcase styleName) (strcase "AEC_AC_Keynotes"))
(ssadd ent selectList)
(setq i (1+ i))
;; 3. Highlight and grip the matched MLeaders if any were found
(if (> (sslength selectList) 0)
(progn
(sssetfirst nil selectList)
(princ (strcat "\nSuccess: Selected " (itoa (sslength selectList)) " Multileaders using style 'AEC_AC_Keynotes'."))
(princ "\nNotice: Multileaders found in Paper Space, but none match style 'AEC_AC_Keynotes'.")
(princ "\nNotice: Absolutely no Multileaders exist in Paper Space.")
(princ)
(command "-layer" "make" "C-ANNO-KEY" "color" "2" "" "")
(command "_.CHPROP" selectList "" "_LA" "C-ANNO-KEY" "")
