Select first and then run program
Hi guys,
I'm trying to make a lisp involving ssget.
Is there a way for user to select the objects before running the lisp and that he would not be ask again to select object by the ssget?
I mean, like in autocad commands you can select and then choose command, or you can choose command and then select.
Satoews
(or setthisvariable
(setq setthisvariable (ssget)))
(defun c:trythis () ;; don't put setthisvariable in the parenthesis
Shawn T
Kent1Cooper
Yes.  User something like:
(if (not (setq ss (ssget "_I"))); if there is not an Implied [= pre-] selection [if there is, it will put that into 'ss']
  (setq ss (ssget)); then -- ask the User to select
); if
Then go on to do what you want with the 'ss' selection set.  Add whatever filtering you like to either selection -- that is, even a preselection like that can filter for specific characteristics among the pre-selected objects, and only "keep" the qualifying ones.
Kent Cooper, AIA
ВeekeeCZ
@Anonymous wrote:
Hi guys,
Use just (ssget) as it is. It works native. Try it. No need for "I" parameter.
Edit: Don't get me wronk, ssget's "I" parametr is very useful... it allows you to do one thing if you have some object preselected, the other if not. Asi this example:
Spoiler
(defun C:SetByLay ()
 (if (ssget "_I")
   (command "_.setbylayer" "_y" "_y")
   (progn
     (command "_.-color" "BYLAYER"
	      "_.-lweight" "BYLAYER"
	      "_.-linetype" "_s" "BYLAYER" "")
     (if (eq (getvar "pstylemode") 0)
       (command "_.-plotstyle" "_c" "BYLAYER" ""))))
  (princ)
