Select blocks in all layouts
mruPRQUJ
Message 1 of 20
mruPRQUJ
Hi there,
This lisp below is from Lee MAC. I was attached here as well. It selects blocks based on block name, tag and attribute in the current layout. Could you please make some modification to select the blocks in all layouts in the same file? thank you very much in advance. 🙂
;; Block Selection - Lee Mac
;; Selects all blocks in the current layout with a given block name or which contain a specified attribute tag and/or value.
(defun c:bsel ( / att atx blk cnt ent enx flg idx sel str tag )
(setq blk (strcase (getstring t "\nSpecify block name <any>: "))
tag (strcase (getstring "\nSpecify attribute tag <any>: "))
str (strcase (getstring t (strcat "\nSpecify attribute value" (if (= "" tag blk) ": " " <any>: "))))
(if (not (= "" str tag blk))
(if
(and
(setq sel
(ssget "_X"
(append
'((000 . "INSERT"))
(if (not (= "" tag str)) '((066 . 1)))
(if (/= "" blk) (list (cons 2 (strcat "`*U*," blk))))
(if (= 1 (getvar 'cvport))
(list (cons 410 (getvar 'ctab)))
'((410 . "Model"))
(progn
(repeat (setq idx (sslength sel))
(setq ent (ssname sel (setq idx (1- idx)))
enx (entget ent)
(cond
( (not (or (= "" blk) (wcmatch (strcase (LM:name->effectivename (cdr (assoc 2 enx)))) blk)))
(ssdel ent sel)
( (member (cdr (assoc 66 enx)) '(nil 0)))
( (progn
(setq att (entnext ent)
atx (entget att)
flg nil
(while
(and (= "ATTRIB" (cdr (assoc 0 atx)))
(not
(and
(or (= "" str) (wcmatch (strcase (cdr (assoc 1 atx))) str))
(or (= "" tag) (wcmatch (strcase (cdr (assoc 2 atx))) tag))
(setq att (entnext att)
atx (entget att)
(= "SEQEND" (cdr (assoc 0 atx)))
(ssdel ent sel)
(< 0 (setq cnt (sslength sel)))
(progn
(princ (strcat "\n" (itoa cnt) " block" (if (= 1 cnt) "" "s") " found."))
(sssetfirst nil sel)
(princ "\nNo blocks found.")
(princ)
;; Block Name -> Effective Block Name - Lee Mac
;; blk - [str] Block name
(defun LM:name->effectivename ( blk / rep )
(if
(and (wcmatch blk "`**")
(setq rep
(cdadr
(assoc -3
(entget
(cdr (assoc 330 (entget (tblobjname "block" blk))))
'("acdbblockrepbtag")
(setq rep (handent (cdr (assoc 1005 rep))))
(cdr (assoc 2 (entget rep)))
blk
(princ)
Accepted solutions (3)
Replies (19)
Message 2 of 20
marko_ribar
Remove this lines from the code...
'((410 . "Model"))
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 20
mruPRQUJ
It did not work. Please see the info below,
Please see attached DWG for your reference. The block name is
It was located in three layouts.
thanks.
Message 4 of 20
paullimapa
You probably modified the code incorrectly.
I followed @marko_ribar instructions and works for me:
;                            (if (= 1 (getvar 'cvport))
;                                (list (cons 410 (getvar 'ctab)))
;                               '((410 . "Model"))
Paul Li
IT Specialist
@The Office
Message 5 of 20
ec-cad
Found those 3 blocks with the 'layout' stuff commented out.
Are you sure you put in the correct blockname ? I first thought the
"I", s were "1", s  did not find those.
Here's what I got:
Command: BSEL
Specify block name <any>: BCH-X-BORD-REVI-TRIA
Specify attribute value <any>:
3 blocks found.
ECCAD
Message 6 of 20
ec-cad
Paulli,
Didn't see your post, was testing .. a few minutes late.
Same result. Sorry for barging in..
ECCAD
Message 7 of 20
paullimapa
no problem..the more the merrier...
Paul Li
IT Specialist
@The Office
Message 8 of 20
Sea-Haven
For me
I use nentsel and pick the attribute this returns tag name, it also returns a selection point, using this point and (ssget pt) it selects the block so can get block name.
(setq tag (nentsel "\nPick an attribute "))
(setq pt (cadr tag))
(setq tagname (cdr (assoc 2 (entget (car tag)))))
(setq ss (ssget pt '((0 . "INSERT"))))
(setq bname (cdr (assoc 2 (entget (ssname ss 0)))))
Message 9 of 20
mruPRQUJ
Hi there,
In the beginning, I made some mistakes. But I downloaded the lisp which you attached here, it did not work for me. The block only in the current layout was selected. I restarted my laptop as well, it did not work.  Could you please provide some advice to me? many thanks. 🙂
Message 10 of 20
paullimapa
Make sure you overwrote the previous bsel.lsp with the revised one.
Open the same dwg that you posted here.
Then repeat the following at the command prompt:
Command: (load"bsel")
Command: BSEL
The command prompt should return:
3 blocks found.
Command:
Do a screen capture of your command prompt again and share that here.
Paul Li
IT Specialist
@The Office
Message 11 of 20
mruPRQUJ
Hi there,
The lisp is good, I made some mistakes.
Is it possible to add an option to pick a block from the screen? can all the selection be deleted? Many thanks. 🙂
Message 12 of 20
paullimapa
Message 13 of 20
ec-cad
Since you may have changed the code, best to upload what you have now.
From there, we can update it to allow for a 'Pick' of a Block.
ECCAD
Message 14 of 20
mruPRQUJ
Thank you!
Message 15 of 20
mruPRQUJ
thanks a lot!
Message 16 of 20
mruPRQUJ
Hi there,
Please see the lisp below, just pick blocks, no delete. thank you!
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/select-blocks-in-all-layouts/m-p/130...
(if
(and
(setq sel
(ssget "_X"
(append
'((000 . "INSERT"))
(progn
enx (entget ent)
(cond
(ssdel ent sel)
( (progn
atx (entget att)
flg nil
(while
(not
(and
atx (entget att)
(ssdel ent sel)
(progn
(princ)
(if
(setq rep
(cdadr
(assoc -3
(entget
blk
(princ)
Message 17 of 20
paullimapa
you're welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 18 of 20
mruPRQUJ
Hi there,
Could you please confirm if replace the first part with the second part? It did not work. I may make some mistakes.
first part
second part
Thank you.
Message 19 of 20
mruPRQUJ
Hi there,
Please see the lisp below, just pick blocks no delete. thank you!
; OP:
(if
(and
(setq sel
(ssget "_X"
(append
'((000 . "INSERT"))
(progn
enx (entget ent)
(cond
(ssdel ent sel)
( (progn
atx (entget att)
flg nil
(while
(not
(and
atx (entget att)
(ssdel ent sel)
(progn
(princ)
(if
(setq rep
(cdadr
(assoc -3
(entget
blk
(princ)
Message 20 of 20
mruPRQUJ
Cheers! thanks again.
