Select & Delete Lines/Text
I'm still very new at LISP and was wondering if anyone could help me understand the syntax/code for selecting and deleting lines and text.
I would like a function that simply selects a line in a known location and deletes it. Then a similar one for text.
I've had a go and came up with this mess :S I'd like to know what I'm doing wrong so I can improve, so looking at the code below what's out of place?
(setq to_be_deleted (ssget "_F" pt1(list 732.6 264.075)pt2(list 829.626 259.55)))
(if ss (command "_.Erase" to_be_deleted ""))
The idea was it would select everything in a box then delete it, but I just get a bunch of errors as I don't fully understand the syntax. If this is the wrong approach I'm happy to go with deleting 1 line/text at a time.
(Sorry if this ends up as a repeat post, this post wasn't appearing for me after creating it.)
Don't worry I managed to work it out myself, here is the code for other people:
(setq pt1 '(827.162 264.702) pt2 '(734.042 259.941))			;Set Selection Points
(setq sstbd (ssget "C" pt1 pt2))					;Select Objects in Box and create selection set
(if sstbd (command "_.Erase" sstbd ""))					;Delete selection set "sstbd"
CodeDing
@Anonymous ,
Good work coming to your own solution.
Here is a little insight for future knowledge, if you do not already know.
;set points
;if objects found in sel set
(if (setq sstbd (ssget "C" pt1 pt2 '((0 . "LINE")))) ;you can add more filters to be sure you only select your LINE or LWPOLYLINE
  ;delete sel set items
);if
Best,
~DD
