Select All Occurences of a Dynamic Block and Bring to Front
I found this post and tried it but it is not working for me because I'm trying to select a dynamic block (https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-bring-blocks-to-front-with-d...).
Is there anyway to do this for dynamic blocks?
_gile
With dynamic blocks we have to select also all anonymous blocs ("`*U*") and then check if their "effective name" matches the searched block names.
Since AutoCAD 2012 we can use getpropertyvalue.
(defun c:demo (/ ss ent)
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 "`*U*,90-13,CE-13,1161B")))) ; Block names
    (progn
      (repeat (setq i (sslength ss))
        (setq ent (ssname ss (setq i (1- i))))
        (if
          (not
            (wcmatch (getpropertyvalue (getpropertyvalue ent "BlockTableRecord") "Name")
                     "90-13,CE-13,1161B"            ; Block names
           (ssdel ent ss)
      (command "_.draworder" ss "" "_front")
  (princ)
For pior versions, we can search deeply in the DXF lists
(defun c:demo (/ ss i elst)
    (progn
        (setq elst (entget (ssname ss (setq i (1- i)))))
        (if (and (wcmatch (cdr (assoc 2 elst)) "`*U*")
                 (not
                   (wcmatch (cdr
                              (assoc 2
                                     (entget
                                       (cdr
                                         (assoc 340
                                                (entget
                                                  (cdr
                                                    (assoc 360
                                                           (entget
                                                             (cdr
                                                               (assoc 360
        (entget
        (cdr
        (assoc 360 elst)
          (ssdel (cdr (assoc -1 elst)) ss)
  (princ)
Gilles Chanteau
GileCAD
GitHub
