select all layers of a particular color and send to back
mpa-la
mpa-la
Hello all, I'm looking for a way to select all objects on layers of a given color so that I can then send all those objects to the back.  So say I have 35 layers that are color 8 in my drawing, I would issue the command, enter the number 8, then it would select all the objects that are on those 35 layers, and send them to the back.  I'm looking for a one command solution for efficient drafting, not a workaround, I got the workarounds already.  Thanks!!
chriscowgill7373
what do you have started for your code?
I would suppose you would prompt for the user to input a color, then look through the layer collection to find all of them that are that color, then create a selection set of the objects on that layer, and send that selection set to back.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
mpa-la
I'm not a programmer, just a user, I only know the bare essentials of lisp.  I do have a similar lisp routine that turns all layers off of a color you choose, perhaps that could be a jumping off point, but I don't know enough to tell.  Here it is if it helps.
;;;;;;;;;;;turns layers off by color
(defun c:loff nil
(or *LayOffByColor-color*
(setq *LayOffByColor-color* 1))
(setq *LayOffByColor-color* (acad_colordlg *LayOffByColor-color*))
(vlax-for layer (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
(if (= *LayOffByColor-color* (vla-get-color layer))
(vla-put-layeron layer :vlax-false)))
(princ)
chriscowgill7373
you could try this:
(defun c:ldr (/ lcolor llist lset)
  (vl-load-com)
  (setq	lcolor (getint "\nPlease specify Layer color:")
	llist  ""
  (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= (vla-get-color x) lcolor)
      (setq llist (strcat llist (vla-get-name x) ","))
  (if (setq llist (vl-string-right-trim "," llist))
    (progn (if (setq lset (ssget "x" (list (cons 8 llist))))
	     (command "draworder" lset "" "b")
	     (prompt "\no items on these layers")
  (princ)
mpa-la
Thanks Christopher, that works perfect!!!!  What an awesome community, so appreciated!
chriscowgill7373
No problem.  There isn't much error checking, I just threw it together and only tested in a few scenarios.  Its a start anyway.
Sea-Haven
For me I would change (setq lcolor (getint "\nPlease specify Layer color:") to pick an object and get color either bylayer or bycolor.
