Select All Blocks by typing Attributes tag
sergiu_ciuhnenco
Message 1 of 16
sergiu_ciuhnenco
Need a help from you guys, want to select all blocks by typing the tag of the attribute POZITIA, sound easy but I can't make it done
Thanks in advance  !!!
Accepted solutions (3)
Replies (15)
Message 2 of 16
john.uhden
100% untested...
(defun POZITIAS ( / ss I obj atts found) (vl-load-com) (and (setq ss (ssget "X" '((0 . "INSERT")(66.1)))) (setq found (ssadd)) (repeat (setq I (sslength ss)) (setq e (ssname ss (setq I (1- I)))) (setq obj (vlax-ename->vla-object e)) (setq atts (vla-getattributes obj)) (setq atts (vlax-variant-value atts)) (foreach att (vlax-safearray->list atts) (and (= (strcase (vlax-get att 'Tagstring)) "POZITIA") (ssadd e found) ) ) ) found )
You can probably use it in most any AutoCAD native command, e.g.
Command: Select
  Select objects: (pozitias)
John F. Uhden
Message 3 of 16
Ranjit_Singh
Maybe like this. Minimal testing. There maybe additional considerations depending on the type of blocks; dynamic, nested etc.
(defun c:somefunc  (/ ent etdata nf ss1 ss2)
 (setq ss1 (ssget "_x" (list '(0 . "insert") '(66 . 1))))
 (and ss1
      (setq ss2 (ssadd))
      (mapcar '(lambda (x)
                (setq ent x
                      nf  t)
                (while (and (/= "SEQEND" (cdr (assoc 0 (setq etdata (entget ent))))) nf)
                 (and (= (cdr (assoc 0 etdata)) "ATTRIB")
                      (= "Pozitia" (cdr (assoc 2 etdata)))
                      (setq ss2 (ssadd x ss2)
                            nf  ()))
                 (setq ent (entnext ent))))
              (mapcar 'cadr (ssnamex ss1))))
 (sssetfirst nil ss2)
 (princ))
Message 4 of 16
sergiu_ciuhnenco
100% non working 🙂
I tried but unfortunately it doesn't work
Could you please rewiew it !!!
But for the last time let me explain what I want : run lisp just type the tag of attribute POZITIA , for example "50" and select all blocks with this attribute tag
Message 5 of 16
sergiu_ciuhnenco
Hi Ranjit.Singh !!!
your lisp is working but it does not give the solution for wich I was asking for,let me explain what I want : run lisp just type the tag of attribute POZITIA , for example "50" and select all blocks with this attribute tag
Message 6 of 16
sergiu_ciuhnenco
probably I was was asking wrong question , I think I have to say not attribute tag but attribute value
Message 7 of 16
DannyNL
So you want to select based on attribute tag AND value? Right?
Well, this is my version. Basically almost the same as John's but in my own way of non-efficient and longer coding Smiley Wink
The attribute tag has been fixed on the value "POZITIA" but if you want to search for other tags as well, just remove the semicolon on the first line and put it before the second line so you will get an additional question tom provide the tag as well.
(defun c:SelBlk (/ SB_FindAtt SB_FindVal SB_Selection SB_FoundSel SB_Count SB_BlkEnt)
   ;(setq SB_FindAtt (getstring "\nAttribute Tag  : "))
   (setq SB_FindAtt "POZITIA")
   (setq SB_FindVal (getstring "\nAttribute Value: "))
   (if
      (setq SB_Selection (ssget "_X" '((0 . "INSERT")(66 . 1))))
      (progn
         (setq SB_FoundSel (ssadd))
         (setq SB_Count 0)
         (repeat (sslength SB_Selection)
            (setq SB_BlkEnt (ssname SB_Selection SB_Count))
            (if
               (FindAtt (vlax-ename->vla-object SB_BlkEnt) SB_FindAtt SB_FindVal)
               (ssadd SB_BlkEnt SB_FoundSel)
            (setq SB_Count (1+ SB_Count))
         (if
            (> (sslength SB_FoundSel) 0)
            (sssetfirst nil SB_FoundSel)
   (princ)
(defun FindAtt (FA_BlkObject FA_AttTag FA_AttVal / FA_Attributes FA_Return)
   (if
      (and
         (= (type FA_BlkObject) 'VLA-OBJECT)
         (= (vla-get-ObjectName FA_BlkObject) "AcDbBlockReference")
         (= (vla-get-HasAttributes FA_BlkObject) :vlax-true)
         (= (type FA_AttTag) 'STR)
         (= (type FA_AttVal) 'STR)
      (progn
         (setq FA_Attributes (vlax-safearray->list (vlax-variant-value (vla-GetAttributes FA_BlkObject))))
         (foreach FA_Item FA_Attributes
            (if
               (and
                  (= (strcase (vla-get-TagString  FA_Item)) (strcase FA_AttTag))
                  (= (strcase (vla-get-TextString FA_Item)) (strcase FA_AttVal))
               (setq FA_Return T)
   FA_Return
Message 8 of 16
sergiu_ciuhnenco
Thanks YOU !!!!!!
Exactly what I needed !!!
It will be very helpful !!!
Message 9 of 16
DannyNL
Glad we could help Smiley Happy
Message 10 of 16
JerVanK
I'm trying to run this Lisp in 2016 and only having partial luck.
these are my 2 question that seem to be causing issues
Does the tag valve search entry have to be complete? (yes)
and can the value have any spaces at the end? (no)
I'm trying to select block with a computer generated valve of "#05 " (with 2 spaces after the number).
Is these a way to find and select a block with these attribute tags?
Message 11 of 16
dlanorh
Is "#05  " the block name, the attribute tag name or the tag value (textstring)?
If it is a tag name or tag value a simple adjustment to the code can be made to account for the 2 spaces if they are at the end of the string
I am not one of the robots you're looking for
Message 12 of 16
john.uhden
(wcmatch str "*# ")
John F. Uhden
Message 13 of 16
nanja_c86
I was searching on the forum for this kind of lisp, got this one this is helpfull.
But need some changes as below.
Need to Count the number of blocks and place a circle to its ins point and show alert message that this many circled placed.
Thanks in advance.
Message 14 of 16
Sea-Haven
To nanaj.c86 this would be better posted as a new request. Need to count the blocks just a grand total or each name counted ???
Message 15 of 16
nanja_c86
@Sea-Haven
As per your suggestion i have posted as new, explained there what i  need.
here is he link
Count and place circle to All Blocks by typing Attributes tag values - Autodesk Community
Thank you.
Message 16 of 16
Kyle.para
I have used the code provided by Danny and it works, but I need it tweaked a little bit , if anyone cares to lend a hand.
We have a block that has the same attribute tag and block name. Except one attribute value is LC01, LC02 etc. and the other one is SD01, SD02 etc. We only need to select all of the LC## ones.
I can get it to work by changing the code to select LC50 for example, but how can I modify it so that it finds all the blocks with a value for the attribute with a wildcard. Like LC** for example.
(setq SB_FindVal "LC50")
