Searching for Positive Spark
Today I decided I am ready to stop being so inefficient, so this query will amount to me hoping to find a specific person who worked very briefly in the same work role as me as a, and failing that, other people who can direct me to his blog/website, and thirdly people I can learn from how to do the following:
So I am working with AutoCAD, Excel, and another program that is used to process some types of information (I'll call it A for now). A exports a text file, Excel grabs certain values related to blocks, and I end up with a .dwg with a neat row of blocks added to it. Nice and handy.
I want to make a LISP that exports block names with a certain name format so I can keep a running count of which blocks I need to add to the system, since not all blocks are common enough to be relevant, and the system is still very incomplete, as the previously mentioned blogger is well aware.
I also want to use an export of block names in a drawing where I will use those names with a LISP that can import the blocks from their file location, and be able to sort them, according to their block names.
That's all my problem (well not all, but the most pressing atm), but run through this neat code before you go.
// assume breaks and correct syntax/punctuation since youre doing it already.
(giving response = coolfactor(~Q~)
switch (response)
case way past cool:
blog guy (until discovered otherwise, known as Coolbro Johnson) discovers this one day
case cool:
guy(s) who kept a look out for me to post finally (per Coolbro's instructions) does
case highly improbable:
someone who read a particular post of Coolbro's a while ago does
case pretty cool:
direct me to a blog that leads me to Coolbro
case also pretty cool:
directs me to a different blog that helps me figure out LISP enough
case nice
doesn't know the answer
case not cool/terribad
someone reports the post and I get into trouble X.x
default
has a good week!
*you're
In order for this post to be easily findable by the blogger, I'll add some terms/names that might help me out: Positive Spark, Block Import, Dakota Cantrell, Clint Ingram, Coolbro Johnson, Anita Grencie, 807, Cameron J, Jarrod Knapp, Jamon, Tulsa, Oklahoma, Oklahoma City.
