Visual LISP, AutoLISP and General Customization
search text, move to new layer
3 REPLIES 3
318 Views, 3 Replies
I've been trying for a month or so to find a way move certain text with a lisp routine or anything to a new layer. For instance, there are "land hooks" drawn on a map, and there are 4000 of them. They are all the letter Z. I want to move all of those to their own layer, and I don't want to select all 4000. There's also strings of other texts I'd like to be able to search, and move to a layer but just that letter Z would help immensely. I'd also like to be able to search for R#### with 4 numbers after the R and move all those text entities to a separate layer. Any ideas on a method, or know of a lisp routine that'd allow this? Thanks for any direction!
3 REPLIES 3
check out Quick Select on your Shift-right click menu.
highlight grips on a text object then Shift right click
Apply to: Entire Drawing
Object Type: Text
Properties: Contents
Operator: = Equals
Value: Z
hit OK
Command: Select
Select Objects: Previous
and change their layer all at one time
Dave
DDP
Thanks so much! I used FILTER to do the same thing. Using Text Value = Z
Then using text value = R##### which uses # as the wildcard for numbers. Saved me hours upon hours! Maybe 100 hours?
These other wildcards I found useful.
# (Pound)
Matches any numeric digit
@ (At)
Matches any alphabetic character
. (Period)
Matches any nonalphanumeric character
* (Asterisk)
Matches any string and can be used anywhere in the search string
? (Question mark)
Matches any single character; for example, ?BC matches ABC, 3BC, and so on
~ (Tilde)
Matches anything but the pattern; for example; ~*AB*matches all strings that don't contain AB
Matches any one of the characters enclosed; for example, [AB]C matches AC and BC
Matches any character not enclosed; for example, [~AB]C matches XC but not AC
Specifies a range for a single character; for example, [A-G]C matches AC, BC, and so on to GC, but not HC
` (Reverse quote)
Reads the next character literally; for example, `~AB matches ~AB
Thanks for the tip!
carlomaagno wrote:
> Thanks for the tip!
thanks for the wildcards. There's a couple I wasn't aware of
Dave
DDP
Forma Design Contest
