Script ?
Script ?
Script ?
Hi All
Anybody please look at this attached script file which does not work. I want to put these dimensions in a profile drawing labeling slopes or dias.
Which i extract from an excel file.
Thanks in advance
AAK
steven-g
Your problem is when a script expects text input, it doesn't know when the text finishes, so you have to use a new line (this problem occurs anywhere text is used within scripts). Try the following dimlinear 0,000 50,00 t TEXT-1 0,0 dimlinear 105,0 155,0 t TEXT-2 0,0 dimlinear 155,0 210,0 t TEXT-3 0,0 dimlinear 210,0 260,0 t TEXT-4 0,0 dimlinear 260,0 311,0 t TEXT-5 0,0 dimlinear 311,0 362,0 t TEXT-6 0,0 dimlinear 362,0 414,0 t TEXT-7 0,0 dimlinear 414,0 475,0 t TEXT-8 0,0
steven-g
Ignore the last post and look at the attached file Sorry doesn't work either. Our system at work (citrix apparently) blocks any attachments and completely mucks up any formatting. All you need do is when the text items finish create a new line for the last 0,0 input
ВeekeeCZ
I think @steven-g's sugestion is good. Your script has to look like this:
0,0
0,0
0,0
This can be done in Excel in one row where the enter is char(10) function. But after that you cannot paste the code into command line directly, because Excel wraps the text into quotation marks. So copy that into Notepad first, erase surroundings quotation marks and then paste it into Autocad.
steven-g
@ВeekeeCZ Thats exactly what I was trying to show Smiley Wink unfortunately our system at work sabotages all attempts.
