Script to run PUBLISH got "Invalid file."
wesbird
wesbird
I want to create PDF from DWG file, for each DWG file, some layouts will print out as PDF file, not all layouts. I also like to use DWG TrueView to do it, because it's free.
Here is how I goes,
1. I start from AutoCAD, I run PUBLISH, pick the layout I like to use, change file type to Single-sheet file, output as PDF. save sheet list DSD file. it works
2. then I set FILEDIA = 0, run -PUBLISH, enter the DSD file I just created, it works too.
3. now I create a scr file, just like:
-PUBLISH
"C:\B\CLGRAB01-001A-FP01.dsd"
in AutoCAD, I run SCRIPT, enter the scr file I just created, I got error message like:
Command: SCRIPT
Enter script file name <C:\B\CLGRAB01-001A-FP00.scr>: c:\b\clgrab01-001a-fp01.scr
Command: -PUBLISH
Enter name of sheet list <C:\b\clgrab01-001a-fp01.dsd>: "C:\B\CLGRAB01-001A-FP01.dsd"
Invalid file.
Please verify the correct path was given.
I already tried this for 3 different files and locations. all came the same error. What could be wrong.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
paullimapa
Have you tried putting into the script file the name of the sheet list file without the quotes, ie:
-Publish
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
leigh.menzel
How can you create the DSD file from Trueview in the first place though?  It seems there is a way to do it, but I can't find doco. on this anywhere.  Does anyone have any ideas on how to automate the creation of a DSD file from Trueview (like just going into the PUBLISH command and then cancelling out and selecting Yes to save the DSD file?)
paullimapa
Just click on the Save button
Paul Li
IT Specialist
@The Office
leigh.menzel
Paul.  Thanks for the feedback, but I want to do it automatically (no user intervention/clicking).  A way to open the PUBLISH command without having to specify a DSD file first.  If one specifies -PUBLISH in the SCR (/b script) file, Trueview insists on requiring a DSD file to open the Publish command, which is what I don't have yet.
Sea-Haven
There is some posts about making a DSD file via lisp, but you would have to make it 1st then it should be available for Trueview. Trueview does not have a crystal ball.
leigh.menzel
Yep thanks, I am working on that now.  Just can't believe it's something that is so easy to do manually in Trueview and yet seems impossible to automate.  I say "seems" because nothing is impossible!
