Script to replace block with dynamic block
tevansERD
tevansERD
I need to replace a block with a dynamic block in multiple drawings via script. Blockreplace doesn't work and I have tried renaming the block the same as the dynamic block then use insert to redefine the block and that didn't work. I am out of ideas.
Replies (9)
cadffm
It should work, but without your data (DWG with inserts of old block and a dwg with your new block)
we can not check where you did an mistake)
Sebastian
tevansERD
I have attached a drawing with the old blocks (ElecTest.dwg) and the block RecessedLight.dwg. Thanks for the assist
marko_ribar
It worked on my PC... Renamed existing block "Can Light" with "RecessedLight" with RENAME command... Then I used INSERT command and do browse on file RecessedLight.dwg... Upon OK, CAD asked do I want to redefine existing block RecessedLight => Yes and I inserted one block on empty space... CAD automatically replaced all blue blocks with new dynamic yellow... Then you have to delete last insertion... And for multiple DWGs, I don't have decent answer yet... All I can think is that you manually follow these steps for each DWG you have... BTW. I don't think you can bypass dialog box prompt CAD pops up asking for redefine block...
Marko Ribar, d.i.a. (graduated engineer of architecture)
cadffm
". BTW. I don't think you can bypass dialog box prompt CAD pops up asking for redefine block..."
There is no dialog window when you use the commandline command -INSERT
(this command start when you type-in -INSERT and also when you start INSERT by automation.
And for the "batch" part - the are 4 different ways and 9999 variants to do this.
Very simple for Users is to use special programs like ScriptPro
Sebastian
marko_ribar
Somehow I don't think anything you and I replied works for OP... He wouldn't pull out this question if all is fine - I had to test it with his DWGs as I was also confused with this question... I can't replicate OPs situation though, so I can't tell what the problem is, but if all was as we replied we would get kudos or solution would be already marked... I beleive you are right for automation scripting process - I just haven't thought that at the moment I replied; I wanted to confirm that manuall approach is working as I tested it with OPs examples... Still what would be the best way for automation process (fastest and the most reliable) I can't tell... Maybe if someone would write concrete code for usage with just AutoCAD and no using additional plugins like ScriptPro, post would maybe be marked as solution (with condition that it works for OP too)... This way I think we won't get not even confirmation we were testing and checking the task in correct manner...
Cheers and all the best to you Sebastian.
Regards, M.R.
tevansERD
seems that if it works with manual input a script should work. I use Script pro all the time.  I will keep playing with the code. Good to have a confirmation that someone else could get it to work.
cadffm
Not perfect, but as sample enough.
You should set the default visibility to CAN and not to F-LIGHT, if you like to swap the old block..
;==START==
; Nobody should use and change system-layers, so it isn't a problem to thaw layer 0 and use them as current layer
; to make sure that i can delete my (last) insert / you can not erase objects from locked layers.
_.-LAYER
_unlock 0
_thaw 0
_set 0
_.-RENAME _block
"Can Light"
RecessedLight
_.-INSERT "RecessedLight=D:/z/RecessedLight.dwg"
0,0
1
0
_.ERASE
_last
;==END===
Sebastian
marko_ribar
I don't use ScriptPro, but too late for party...
(defun c:replaceblock ( / oldblk oldname newblk newname )
  (vl-load-com)
  (while
    (or
      (not (setq oldblk (car (entsel "\nPick old block...(dynamic or static)"))))
      (/= (cdr (assoc 0 (entget oldblk))) "INSERT")
    (prompt "\nMissed or picked wrong entity type...")
  (setq oldname (vla-get-effectivename (vlax-ename->vla-object oldblk)))
  (setq newblk (getfiled "Select DWG - new block...(dynamic or static)" "\\" "dwg" 16))
  (setq newname (cadr (fnsplitl newblk)))
  (vl-cmdf "_.rename" "_b" oldname newname)
  (vl-cmdf "_.-insert" (strcat newname "=" newblk))
  (vl-cmdf)
  (princ)
For single DWG execution...
And for automation :
;; This is sub function that is used for replacement of block "Can Light" to "RecessedLight" from DWG "RecessedLight.dwg" placed in AutoCAD Support File Search Path
(defun replaceblk ( / oldname newblk newname )
  (setq oldname "Can Light")
  (setq newblk (findfile "RecessedLight.dwg"))
  (command "_.rename" "_b" oldname newname)
  (command "_.-insert" (strcat newname "=" newblk) "_non" (list 0.0 0.0 0.0) 1.0 1.0 0.0)
  (command "_.erase" "_l" "")
;; This command function (c:runscript) creates "replaceblk.scr" script file that is placed in folder where reside DWG files you want to process through scripting - all DWG files must have block "Can Light" that is to be replaced with block "RecessedLight" as block-DWG "RecessedLight.dwg" that is placed in AutoCAD Support File Search Path
(defun c:runscript ( / path files scrfn )
  (setq path (acet-ui-pickdir "Select folder with DWG files to process replace block procedure..."))
  (setq files (vl-directory-files path "*.dwg"))
  (setq scrfn (open (strcat path "\\replaceblk.scr") "w"))
  (foreach filen files
    (write-line "OPEN" scrfn)
    (write-line (strcat path "\\" filen) scrfn)
    (write-line "((lambda ( / oldname newblk newname )(setq oldname \"Can Light\")(setq newblk (findfile \"RecessedLight.dwg\"))(setq newname (cadr (fnsplitl newblk)))(command \"_.rename\" \"_b\" oldname newname)(command \"_.-insert\" (strcat newname \"=\" newblk) \"_non\" (list 0.0 0.0 0.0) 1.0 1.0 0.0)(command \"_.erase\" \"_l\" \"\")))" scrfn)
    (write-line "QSAVE" scrfn)
    (write-line "CLOSE" scrfn)
    (write-line "" scrfn)
  (close scrfn)
  (vl-cmdf "_.script" (strcat path "\\replaceblk.scr"))
  (princ)
HTH., M.R.
P.S. You have to remove replaceblk.scr after process...
marko_ribar
Hi, there is slight change to my hard coded script inside lisp... See here (reverse link) : https://www.cadtutor.net/forum/topic/65240-lee-mac-battelsp/?do=findComment&comment=549024 M.R.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
