Script to join all lines
I am trying to write a script to join all lines using the Pedit / join command. I then intend to use ScriptPro to run the script on lots of drawings. I can't work out the correct code having tried lots of variation's. Here's a couple of attempts that don't work. If you can give me any help as to what I am doing wrong that would be greatly appreciated 🙂
PEDIT
Select polyline or [Multiple]: multiple
Select objects: all
Convert Lines, Arcs and Splines to polylines [Yes/No]? <Y> yes
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: join
Join Type = Extend
Enter fuzz distance or [Jointype] <0.00>: 0.0000
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: exit
qsave
PEDIT
multiple
all
yes
join
Extend
0.0000
exit
qsave
Thanks in advance
M
ВeekeeCZ
Why you don't just use the JOIN command?
I could get that to work either! Humph! (This is the first Script I have tried to write)
ВeekeeCZ
Maybe one more line behind the selection
all
join
Thanks that has helped but I am not quite there yet. Below is the code I have so far. The Pedit part works and the +saveas part works. However the problem is after the Pedit part has run I can't figure a way to exit the command before the +saveas part.
PEDIT
multiple
all
join
0.0000
+SAVEAS
dxf
2013dxf
16
yes
this is the command line when the above script runs...
Command: PEDIT
Select objects: all 312 found
Select objects:
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>: 0.0000
98 segments added to 41 polylines
Command:  PEDIT
Select polyline or [Multiple]: +SAVEAS
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Multiple]:
all / any help appreciated!
M
ВeekeeCZ
PEDIT
multiple
all
join
0.0000
 <- there is the space, should not -- just an empty line
+SAVEAS
dxf
2013dxf
16
yes
Spoiler
PEDIT
multiple
all
join
0.0000
+SAVEAS
dxf
2013dxf
16
yes
