Script to Clean Architectural Backgrounds
iabonce
iabonce
I need to come up with a script to simplify the cleaning of architectural backgrounds. I have the basics down but need help when needed to merge multiple layers into one. For example, I'm looking to set all layers that contain "wall" to a layer called "x-wall". Can someone share their script or provide guidance to the best way to accomplish this?
CodeDing
@iabonce,
It appears @alanjt_ has provided a great function for this matter HERE. I am unable to test it at the moment, but calling it would be something like...
(defun c:TEST ( / )
(_LayMrg "*wall*" "x-wall")
);defun
Best,
~DD
dbhunia
For script .... Try like this for single layer.....(tested in Autocad 2007)
_LayMrg n wall
n x-wall
y
For lisp ..... Try like this for multiple layer...(tested in Autocad 2007)
(defun c:TEST ( / sset)
(setq sset (ssget "_A" '((8 . "*wall*"))))
(command "_chprop" sset "" "LA" "x-wall" "")
Or you can use this above lisp directly in script .....like....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
