Script to build a line through the points
Hello.
I have something like 3d net created from bars. All bars are 3d solids. I need to chenge bars to lines which must come along main axle of 3d solid. Is it possible to make script for this purpose?
hmsilva
@Anonymous wrote:
Hello.
Hi antoshka_2012,
try this code, pipes by Stefan M.
Hope this helps,
Henrique
Hello. Thank you for response.
I am newbie in all script stuff and if I understand right, Stefan's script only found central points of cylinders. It is enough complicated for me to make something appropriate from his script.
Also I founded another way to get the point.
But thanks again 🙂
hmsilva
But thanks again 🙂
You're welcome, antoshka_2012
Stefan's 'pipes' will create/entmake a 'LINE' in the current layer.
(entmake (list '(0 . "LINE") (cons 10 (car a)) (cons 11 (cadr a))))
Try to create a new layer, run Stefan's code and isolate the new layer to see the new lines...
Hope this helps,
Henrique
Strangely, I have tried like you writed, but don't had any lines.
hmsilva
Strange, I did test the code in a old AC2010, and It worked as expected...
I did post a different approach (very slowly one) in msg#13 'demo_h.lsp' try to remove
(-3 ("CPD1"))
; from
(setq ss (ssget '((0 . "3DSOLID") (-3 ("CPD1")))))
and try the code, it will add lines in layer '_Demo'...
Hope this helps,
Henrique
