Script timing inside lisp
I'm calling a script from inside a lisp routine, but the lisp is continuing to execute before the script is finished. How can I prevent this?
Partial code example:
(command "script" "myscript")
(alert "what the heck?")
Given the above, myscript will NOT execute UNTIL I CLICK OK on the alert box!
How do I get the alert box to only appear AFTER myscript has run to completion?
Karen
Karen
(command "_.script" "myscript")
(while (= (logand (getvar "cmdactive") 4) 4)
(command pause))
(alert "what the heck")
__
"Karen" wrote in message
news:eee234a.0@WebX.SaUCah8kaAW...
this?
alert box!
completion?
Sorry, that's the way it is.
My theory is that long long ago in the days of overlays, the AutoLISP
overlay and the script overlay occupied the same memory space. You
couldn't have them both at the same time.
For whatever reason, scripts activated from LISP start executing when the
LISP completes.
What are you trying to do? Maybe you can do it without a script ...
jrf
Member of the Autodesk Discussion Forum Moderator Program
this?
alert box!
completion?
Thanks, Paul. I think your code works as it should, but I'm not getting the results I need. See my new post.
K
K
