SCRIPT or LISP for overlaying
Akshay.Sharma2
Message 1 of 11
Akshay.Sharma2
Hello there,
To use with Lee's Script Writer, I'm working on developing a lisp. I can't seem to get it to function.
I want to do the following:
  1. open the *file*
  2. move to model space
  3. overlay an dwg at a coordinate
  4. reconcile layers
  5. save
  6. close
1,2,5,6 are done in Script Writer and are working file as i have tested them.
This is what i came up with:
(defun c:lol ()
(Command "TILEMODE" "1" "FILEDIA" "0" "-ATTACH" "R:\Legend templates_JG.dwg" "O" "100,100" "1" "1" "0" "-LAYER" "E" "*" " ")
The attach command fails to use the specified location, and the reconcile layer command hangs at the end and does not exit. Please assist this autolisp novice.
Thank you very much.
Accepted solutions (3)
Replies (10)
Message 2 of 11
paullimapa
instead of "R:\Legend templates_JG.dwg"
try: "R:\\Legend templates_JG.dwg"
or:
"R:/Legend templates_JG.dwg"
Also if there are no layers to reconcile in the drawing then this part of the code will fail:
Paul Li
IT Specialist
@The Office
Message 3 of 11
paullimapa
found this nice code to check if there are any unreconciled layers in current drawing.
if there are, will return a list. if there are none will return nil:
How to list unreconciled layers. (theswamp.org)
; unreconlayers function returns list of layers that are unreconciled or nil if none
; https://www.theswamp.org/index.php?topic=50448.0
(defun unreconlayers ( / def dic lay lst )
    (while (setq def (tblnext "layer" (not def)))
        (setq lay (cdr (assoc 2 def))
              dic (cdr (assoc 360 (entget (tblobjname "layer" lay))))
        (or (and  dic (dictsearch dic "adsk_xrec_layer_reconciled"))
            (setq lst (cons lay lst))
    (reverse lst)
Paul Li
IT Specialist
@The Office
Message 4 of 11
Akshay.Sharma2
R:/Legend templates_JG.dwg this one is working.
Message 5 of 11
paullimapa
Yes when using lisp replace \ with / or \\ because lisp uses \ as escape code
Paul Li
IT Specialist
@The Office
Message 6 of 11
Akshay.Sharma2
Thank you for the insight.
Now, I am trying to figure out a way to utilize the "unreconlayers" function so that if it finds layers to reconcile , it does reconciliation else close it.
Message 7 of 11
paullimapa
easy:
(If (unreconlayers)
(progn
do this when there are unreconciled layers
) ; progn
(progn
else do this when there are none
) ; else
) ; if
Paul Li
IT Specialist
@The Office
Message 8 of 11
Akshay.Sharma2
I tried this :
(defun C:fixreconcile ( / def dic lay lst )
    (If (unreconlayers)
(progn (command "-LAYER" "E" "*" " ")
) ; progn
(progn(princ "\nNo layers to reconcile.")
) ; else
) ; if
It is working but still does not closes and shows:
Command: FIXRECONCILE -LAYER
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: E
Enter name list of layer(s) to turn reconcile or <select objects> or [?]: * Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]:
Invalid option keyword.
; error: Function cancelled
Message 9 of 11
paullimapa
why add a space between the quotes?
Don’t do this:
Do this:
(command "-LAYER" "E" "*" "")
Paul Li
IT Specialist
@The Office
Message 10 of 11
Akshay.Sharma2
Thank you for guiding me out
Message 11 of 11
paullimapa
You are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
