Script Issue
Script Issue
Script Issue
How to work on Script in autocad 2014. Is it not easy like autocad 2000.
imadHabash
Hi and Welcome to AutoDesk Forum,
Try to start from here >> Link <<
Imad Habash
Nice to get reply.
Thanks Mr.
I will follow and get back to you.
BeKirra
With a big jump from v2000 to v2014, you may look into these additional system variables which were introduced since 2014 version:
1) TRUSTEDPATHS
2) SECURELOAD
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
