script for closing drawings now needs to be automated
Can someone advise how I should setup this script so it's not a hassle for the end user.
The script makes sure all drawings are saved in the same state when shut at the end of the day.
I want to create a save and close that uses the script I have put together to leave all drawings in the same state after use.
Please help!!
I have attached the script.
;; DWGEXIT.scr
LAYER SET 0
PURGE ALL * N
AUDIT Y
XREF U *
VISRETAIN 1
ZOOM EXTENTS
;;-END OF SCRIPT-
DannyNL
Multiple options to achieve what you want, like i.e. create a custom button (ribbon/toolpalette) to run your script or a LISP routine
This code does the same as your script. You can include this code in one of the startup LISPs if you have one (ACADDOC.LSP/[MENU].mnl) or you can create a separate centralized file and add it to your APPLOAD startup suite (profile). With the last option make sure all users are loading and using your new/updated profile. Type the command QCLOSE to run.
(defun c:QClose ()
   (setvar "CLAYER" "0")
   (setvar "VISRETAIN" 1)
   (repeat 3
      (command ".-PURGE" "ALL" "*" "N")
   (command ".AUDIT" "Y")
   (command ".XREF" "U" "*")
   (command ".ZOOM" "E")
   (command ".QSAVE")
   (command ".CLOSE")
Thank you it works really well, added a open version as well.
DannyNL
You're welcome and glad I could help Smiley Happy
