Visual LISP, AutoLISP and General Customization
Saving over multiple DWGs
8 REPLIES 8
Message 1 of 9
etilley327KA
417 Views, 8 Replies
Looking for help, im trying to make a quick way to save a dwg over multiple dwgs. What am I missing, its not saving?
(vl-load-com)
(defun c:test (/ *error* 1a)
  (defun *error* ( msg )
        (setvar "cmdecho" 1)
        (setvar "filedia" 1)
        (if (not (member msg '("Function cancelled" "quit / exit abort")))
            (princ (strcat "\nError: " msg))
        (princ)
(setvar "cmdecho" 0)
(setvar "filedia" 0)
(while
  (/= 1a "")
(setq 1a "")
(setq 1a (getstring "\nEnter job number or enter when done "))
  (if
      (progn
      (vl-cmdf "_save"  1a  "Y")
      (princ (strcat "\nSaved [" 1a "]"))
(princ "\nDone")
(princ)
8 REPLIES 8
Message 2 of 9
Moshe-A
in reply to: etilley327KA
@etilley327KA  hi,
To achieve this, you have to move to ActiveX  (vla \ vlax) functions but before that try SAVEALL command 😀
Moshe
Message 3 of 9
Kent1Cooper
Should this:
be this instead?
(/= 1a "")
Kent Cooper, AIA
Message 4 of 9
pendean
What does "enter job number" do exactly? Is that for a new drawing you open but have yet to save? Do you really do that (just asking to understand, not criticizing).
How does SAVEALL command not work for your needs https://www.google.com/search?q=autocad+saveall+command
Message 5 of 9
Kent1Cooper
No, SAVEALL is clearly not what you're looking for.  If I understand correctly, you will supply text strings, and as long as they have some content [are not "" empty strings], each will be the name of a drawing that is a copy of the current drawing, under that name.  [The "Y" is the answer to the question of whether to replace it if it already exists.  If it doesn't, that question won't be asked, and an unknown-command message will go by, but it won't bother anything.]
You say it's not saving.  Is it getting as far as the prompt saying that it did?  You don't include a file path, so are you sure it's not saving?  Are you looking in the right place for the drawing(s) it saved?
Kent Cooper, AIA
Message 6 of 9
etilley327KA
in reply to: Kent1Cooper
It runs through the whole LISP but the drawing is unchanged. When I run the commands manually it saves. Once I get this to work, I was going to add an "if" to check if the job exist before running the "save" command, to have one with and without the "Y". Not sure what's going on here, I'm stumped.
Message 7 of 9
etilley327KA
in reply to: pendean
Im trying to save my current dwg over other dwgs without leaving my dwg.
Message 8 of 9
etilley327KA
Yeah, I missed that. Its still not saving though.
Message 9 of 9
paullimapa
I'm successful in running your lisp code. But you'll have to use \ or / to separate folder names and surround everything with "..." if there's a space in the folder or file name.
For example: I have a folder in my c drive called it 1 2 = c:\1 2 with a drawing named c.dwg under this folder.
I then ran your code and at the prompt if I attempt to enter with a space without surrounding with "..." then it'll fail
Also if I enter "c:\\1 2\\c" it'll fail.
But I'm successful when surround with "..." by entering "c:/1 2/c" & "c:\1 2\c"
Paul Li
IT Specialist
@The Office
Forma Design Contest
