save selection set in drawing
andkal
andkal
Hello
Im trying to save a selection set in drawing with this code
(setq Saved_SS_Gvar (ssget))
(vlax-ldata-put "SETS1" "selsets" Saved_SS_Gvar)
but I get this error:
error: Visual LISP: Input/output objects between document illegally <Selection set: 5f>
I guess I cannot save a selection set with this method. Is there another way?
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Kent1Cooper
You could put them into a GROUP, which if you prefer you can give a name for easy recall.
Kent Cooper, AIA
Sea-Haven
Another could save the handle of each item. The obvious is of course what happens when a object is erased.
andkal
Hello
I noticed now that when I converted the selection set into a list, the code works.
It solves the problem
• Autodesk AppStore
devitg
@andkal As I see you work vl functions
after
(setq obj-ss (VLA-GET-ACTIVESELECTIONSET adoc))
Then you can handle it by
(vlax-for obj obj-ss
Do your stuff
No need to cont , change ent to obj, and so on
Also yo can get the OBJ by
(setq OBJ(VLA-Item obj-ss 0)) ; being 0 the  obj index
Sea-Haven
Are you planning on closing the dwg and reopening ? The selection set may not match the objects unless you use the handle so just save the handles in a list. The entity names can change when close and reopen Google for more info.
