save in 2020
save in 2020
robert06
save in 2020
robert06
After update to Autocad 2020.1 (Civil 2020.1.1 Update) Autocad does not produce a file with line
(command "save" "~"). Also, had a Windows 10 update recently.
Anyone?
cadffm
But?
Alerts?
Nothing?
It isn't a problem on my side (on  win8.1)
Are you testing in commandline? Do it!
Sebastian
robert06
On commandline it works as a sole line.
But within a whole lisp, a temporary file was formed etc savee6bc81b5.tmp, but no dwg was created.
Works in 2019 and used to work in 2020.
Uninstalled now the Dach extention - just guessed, that it would prevent saving some data which was brought in during binding xrefs in the lisp procedure and the lisp started to work again.
thank you.
pendean
Community Legend
Community Legend
What " whole lisp" are you using exactly? Post your full code.
robert06
for instance..
(defun c:tlbind (/ ss1)
(prompt "\Joonise eksport - BIND")
(command ".undo" "begin")
(command "model")
(command "externalreferences")
(load "field2text_CMFT.lsp")
(c:cmft)
(command "-layout" "d" "abi_tingmärgid")
(command "-layer" "th" "0" "on" "0" "s" "0" "")
(if (and (setq ss1 (ssget "x" (list (cons 8 "*_abi*,*_boundary*,*_target*")))))
(command "erase" ss1 "")
(setq *blks*
(vla-get-Blocks
(vla-get-ActiveDocument
(vlax-get-acad-object)
(vlax-for item *blks*
(if (eq (vla-get-IsXref item) :vlax-true)
(progn
(setq ref (tblsearch "BLOCK" (setq xname (vla-get-Name item))))
(if (eq (logand (cdr (assoc 70 ref)) 32) 32)
(command "-xref" "_R" xname)
(command "-xref" "_D" xname)
(command "-layer" "f" "*_abi*" "")
(if (tblsearch "block" "kirjanurk_K-Projekt")
(progn (command "-bedit" "kirjanurk_K-Projekt")(load "Convert_SaveDate_Fields_CSDF")
(c:csdf)
(command "bsave")
(command "bclose")
(load "BurstUpgradedV1-2_xBURST.lsp")
(if (and (tblsearch "block" "z") (setq blks (ssget "_x" (list '(0 . "insert") (cons 2 "z,`*U*")))))
(progn
(setq i 0
xxblks (ssadd)
);; setq
(while (setq hnd (ssname blks i))
(setq blkn (vla-get-effectivename (vlax-ename->vla-object hnd)))
(if (wcmatch blkn "z")
(ssadd hnd xxblks)
);; if
(setq i (1+ i))
);; while
(if xxblks
(progn
(sssetfirst nil xxblks)
(c:xburst)
);; progn
);; if
);; progn
);; if
(setvar "BINDTYPE" 0)
(command "-xref" "_b" "*")
(command "-purge" "r" "*" "n")
(command "-purge" "a" "*" "n")
(command "-scalelistedit" "d" "*" "e")
(load "DXEdel")
(c:dxedel)
(setvar "insunits" 6)
(setvar "ltscale" 1)
(setvar "lwdisplay" 1)
(command "ucs" "w")
(command "base" "0,0,0")
(setq ss1 (ssget "x" (list (cons 8 "TL_vertikaal"))))
(command "chprop" ss1 "" "C" "bylayer" "")
(today)
(setq OldName (vl-filename-base (getvar "dwgname"))) ;; Extracts the Drawing File Name
(setq NewFile (strcat Oldname dates)) ;; Text String for New File
(vlax-invoke
(vlax-get (vlax-get (vlax-create-object "htmlfile") 'ParentWindow) 'ClipBoardData)
'setData
"TEXT"
(strcat NewFile)
(setvar "wipeoutframe" 0)
(command "undo" "end")
(command "_u")
(princ)
(defun c:arbind ()
(command "model")
(c:cmft)
(vl-load-com)
(setq *blks*
(vla-get-Blocks
(progn
(c:csdf)
(command "bsave")
(command "bclose")
(if (setq blks (ssget "_x" (list '(0 . "insert") (cons 2 "l1,z,`*U*"))))
(progn
(setq i 0
xxblks (ssadd)
);; setq
(if (wcmatch blkn "l1,z")
(ssadd hnd xxblks)
);; if
(setq i (1+ i))
);; while
(if xxblks
(progn
(c:xburst)
);; progn
);; if
);; progn
);; if
(load "DXEdel")
(c:dxedel)
(command "ucs" "w")
(today)
(vlax-invoke
'setData
"TEXT"
(strcat NewFile)
(command "_u")
(princ)
