Save copy of drawing to another folder without xrefs
jens.tornblad
Message 1 of 14
jens.tornblad
Hi!
We have a certain process at our workplace where we have a working folder and a folder where we save the most recent version of the file without xrefs. We also have an old folder where the previous version of the drawing in the recent folder is moved to.
Is it possible to automate this proccess with a script?
What we need is:
  • All xrefs detached
  • UCS world
  • Save a copy of the drawing with the same name to the "recent" folder and also move the (if) existing file to "old" with the same name but _YYMMDD at the end.
  • Keep the "working" drawing open in Autocad
Ultimately this would all be achieved with a keyboard shortcut.
Is this possible?
Thanks!
Replies (13)
Message 2 of 14
ВeekeeCZ
This might help you with some...
http://www.cadstudio.cz/en/apps/suresave/
Message 3 of 14
hmsilva
@jens.tornblad wrote:
Hi!
What we need is:
  • UCS world
Is this possible?
Thanks!
Hello jens.tornblad and welcome to the Autodesk Community!
yes, it is possible.
Quick and dirty...
Change the 'old' and 'recent' paths, to the correct ones...
(defun c:demo (/ *error* adoc dwg)
    (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
    (defun *error* (msg)
        (vla-endundomark adoc)
        (cond
            ((not msg))
            ((member msg '("Function cancelled" "quit / exit abort")))
            ((princ (strcat "\n** Error: " msg " ** ")))
        (if command-s
            (command-s "_.undo" "")
            (command "_.undo" "")
        (princ)
    (vla-startundomark adoc)
    (command "_.-xref" "_D" "*")
    (command "_.qsave")
    (command "_.ucs" "_W")
    (setq dwg (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)))
    (if (findfile (strcat "c:/Test/recent/" (getvar 'dwgname)))
        (if (findfile (strcat "c:/Test/old/" dwg "_" (menucmd "M=$(edtime,$(getvar,date),YYMD)") ".dwg"))
            (progn
                (vl-file-delete (strcat "c:/Test/old/" dwg "_" (menucmd "M=$(edtime,$(getvar,date),YYMD)") ".dwg"))
                (vl-file-copy
                (vl-file-delete (strcat "c:/Test/recent/" (getvar 'dwgname)))
                (vl-file-copy
                    (strcat (getvar 'dwgprefix) (getvar 'dwgname))
            (progn
                (vl-file-copy
                (vl-file-copy
        (vl-file-copy
    (*error* nil)
    (princ)
Hope this helps,
Henrique
Message 4 of 14
jens.tornblad
Wow! This is great! Real timesaver! A couple of questions regarding a couple of changes I thought of when I tried it out.
Is it possible to also purge the file? I tried adding
(command "_.-purge" "_A" "*" "_N")
 after
    (command "_.qsave")
without any luck. It purges the file but then the script appears to stop. I only want the "recent" file to get purged.
Also another change, if possible. I don't want the script to overwrite the old file if there's already one with the same date. In other words if an old file is already created for the day I don't want to overwrite that if the script is run again on that day.
Thank you very much for the help.
Message 5 of 14
hmsilva
 after
    (command "_.qsave")
You're welcome, jens.tornblad!
The
should not stop the code,
(defun c:demo (/ *error* adoc dwg dwg_old)
        (cond
            ((not msg))
        (if command-s
        (princ)
    (setq dwg_old (strcat "c:/Test/old/" dwg "_" (menucmd "M=$(edtime,$(getvar,date),YYMD)") ".dwg"))
    (cond ((not (findfile dwg_old))
           (command "_.qsave")
               (progn
                   (vl-file-copy
                   (vl-file-copy
               (vl-file-copy
           (*error* nil)
          (T
           (princ "\nA backup has already been created today... ")
    (princ)
Untested, I don't have AutoCAD in this laptop...
Hope this helps,
Henrique
Henrique
Message 6 of 14
jens.tornblad
 after
    (command "_.qsave")
The
        (cond
            ((not msg))
        (if command-s
        (princ)
           (command "_.qsave")
               (progn
                   (vl-file-copy
                   (vl-file-copy
               (vl-file-copy
           (*error* nil)
          (T
    (princ)
Hope this helps,
Henrique
Henrique
Thanks again! Kudos for superfast reply!
Purge doesn't seem to work, I can see that it runs purge but when i open the "recent" file all excess layers and such still seem to be there.
I also noticed that the working file is saved without xrefs, is it possible to change the order so detaching is done after qsave?
Lastly, with the new version the script doesn't run at all if there is already an old file. Maybe I explained unclear before, but I would like the script to still run, just skip the step where the recent file is moved to old. In other words, I want everything to proceed as before just not overwrite the "old" file.
Thanks again, amazing work!
Message 7 of 14
hmsilva
Once again, untested...
        (cond
            ((not msg))
        (if command-s
        (if command-s
            (command-s "_.qsave")
            (command "_.qsave")
        (princ)
    (command "_.qsave")
    (repeat 3 (command "_.-purge" "_A" "*" "_N"))
            (progn
                ;|(vl-file-delete (strcat "c:/Test/old/" dwg "_" (menucmd "M=$(edtime,$(getvar,date),YYMD)") ".dwg"))
                (vl-file-copy
                (vl-file-copy
            (progn
                (vl-file-copy
                (vl-file-copy
        (vl-file-copy
    (*error* nil)
    (princ)
Hope this helps,
Henrique
Message 8 of 14
jens.tornblad
Thank you very much for this! Like I said, really a timesaver and I just tested it on our real files and it works great. The only thing that I still can't get to work is purge. When I open the created file there are still a lot of stuff that gets deleted when I run purge manually. Should I just give up on purge and delete that line from the script?
Everything else works great. You just saved med tons of time since I had to do this manually before.
Message 9 of 14
hmsilva
Try to change the 'qsave' position in the code
 ;(command "_.qsave") from here
(command "_.qsave") ;<= to here
Hope this helps,
Henrique
Message 10 of 14
jens.tornblad
Hi again!
I was going through some backup files yesterday and noticed that the date format is not exactly as I wanted.
For example todays date, 2016-01-26 gets written as 16126. This is a bit confusing since for example 2016-10-11 gets written as 161011 and 2016-01-01 as 1611.
I looked through the script and found that the reason is probably that the code says YYMD. What I really want is YYMMDD so that 2016-01-01 is written as 160101. I tried to change the code to YYMMDD but that resulted in todays date 2016-01-26 being written as 161426. Which is not what I want. I don't even understand where it got the "4" from.
Is it possible to fix this so that numbers <10 gets a 0 in front of them? This would be much appreciated as it would create consitency in the file order.
Message 11 of 14
hmsilva
Try
(menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)")
Hope this helps,
Henrique
Message 12 of 14
Try changing
to
(menucmd "M=$(edtime,$(getvar,date),YY/MO/DD)")
Message 13 of 14
jens.tornblad
Thanks to both of you, I changed every code that contained YYMD to YYMODD and it seems to have done the trick!
Message 14 of 14
hmsilva
You're welcome, Jens!
Glad you got a solution!
Henrique
