Save as using part of old title
I've been trying to make a function do a save as, and rename the drawing to something that contains part of the old drawing name. The code I have been using to save as is this.
(defun saveas ()
  (setq acadObj (vlax-get-acad-object))
  (setq doc (vla-get-ActiveDocument acadObj))
  (vla-SaveAs doc "abcde.dwg")
The drawing was previously called "12345 - fghij", and I want to rename it to be "12345 - abcde". I have been trying to use vl-string-translate, but I can't seem to get the syntax right. Any help would be greatly appreciated.
Thanks!
Moshe-A
@Anonymous  hi,
check this:
(setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 8) "abcde"))
(vla-saveas doc fname)
enjoy
moshe
(defun saveas ()
Thanks!
dlanorh
Try using
(vl-string-subst new-str pattern str [start-pos])
I am not one of the robots you're looking for
Moshe: Your code works well. I just edited it a bit to fit my needs. Thanks so much for helping me.
