Runtime Part Parameter Configuration Error
RyanMcGinnis3378
RyanMcGinnis3378
I get two "Runtime Part Parameter Configuration Errors" on start up of AutoCad Civil 3d 2021.
1. Public_Stub_Length
2. Riser_Length
I've searched the forums and I haven't been able to find anything to work so far.
Anyone have any suggestions?
hak_vz
Have you got all civil3d updates and/or hotfixes installed for version 2021 ?
There was similar error with civ 3d 2016 that was solved using a hotfix.
Miljenko Hatlak
RyanMcGinnis3378
I've tried using that 2016 hotfix thinking it might solve the problem, just because I've tried everything I know how to do. Currently looking into Updates.
RyanMcGinnis3378
Updates didn't work either.
hak_vz
Only thing that  I found regarding this kind of errors is  this post and this. I'm not sure if this can be used on version 2021. Maybe you should try with technical support?
Miljenko Hatlak
RyanMcGinnis3378
Looks like it's technical support then. Thanks for your help.
