Run lsp on several files
Hi all
I need some help to batch edit files
I have a scr file like this :
open
"C:\myfile1.DWG"
dxfout
16
close
open
"C:\myfile2.DWG"
dxfout
16
close
...etc
and its working fine on many drawings to conver to dxf.
Now instead of converting to dxf, I want to run a lsp file on each drawing. Can I invoke the lsp script on the file from the within this scr?
hmsilva
@Anonymous wrote:
Hi all
open
"C:\myfile1.DWG"
Hello jden77 and welcome to the Autodesk Community!
To run a .lsp file from a script, if the .lsp file is loaded, just add the command in your file for each open dwg, if the lisp is defined as a command, (c:lispcommand), is the lisp is defined as a function (lisp function).
A lisp command is defined as
(defun c:name (....
A function
(defun name (...
Hope this helps,
Henrique
Jonathan3891
Download scriptpro here
You can add a entire folder of drawings to edit.
All your script will need is this:
dxfout
16
Jonathan Norton
Blog | Linkedin
