Run Lisp on Multiple Drawings
Travis.Biddle
Message 1 of 26
Travis.Biddle
I want to run a certain lisp (importmb.lsp) on multiple drawings (hundreds of drawings at times). I have downloaded ScriptPro as this seemed to be what I needed, but I can not figure out how to get it to run the lisp through script. Based on research, this is what my script file is, which I assume is the problem. (load "C:\\support\\importmb.lsp") importmb quit y I load the script into ScriptPro, select which drawings I want to run it on, it opens AutoCAD, but then nothing happens. Any help will be greatly appreciated.
Replies (25)
Message 21 of 26
chris_lee_3
yes you should have a qsave and a close at the end.
(command "_qsave")
(command "_close")
Message 22 of 26
maratovich
Try using this -  AutoRunLisp
Maybe this will help you.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 23 of 26
chris_lee_3
I Played around a bit with scriptwriter today.
As a test I copied the script directly from the website “_.open *file* _.circle 0,0,0 5 _.save _Y _.close ” it worked fine, all the drawings on my desktop now have circles at 0,0.
Tried it again substituting, “zoom e “ for just this part “circle 0,0,0 5 “ and it worked.
I suspect the script can not have close in it.
Message 24 of 26
Sea-Haven
Depending on what you have done both Close and Close Y are valid more than likely needs the Y.
Message 25 of 26
john.uhden
I've never used ScriptPro, but what I see is that your code is only defining an AutoLisp command function.  This will not automatically run itself, so perhaps you have to add to your script (C:<I forgot its name>).
John F. Uhden
Message 26 of 26
Sea-Haven
He is loading then running lisp defun "importmb"
as you say maybe
(load "C:\\support\\importmb.lsp") (c:importmb) quit y
So some other problem.
