Run command on drawing opening on modelspace. I
How can i make LISP command run on Model Space. It is currently running on ActiveLayout. and Im getting the zoomextends version of the Layout view. I want the zoom extends version of the Model Space. Thanks in Advance.
Here is the code i used. i want this code to be altered to work on modelspace rather than layout
(defun c:ZEA (/ acad acdoc aclay)
(vl-load-com)
(setq acad (vlax-get-acad-object)
acdoc (vla-get-ActiveDocument acad)
aclay (vla-get-ActiveLayout acdoc)
(vlax-for layout (vla-get-Layouts acdoc)
(vla-put-ActiveLayout acdoc layout)
(vla-ZoomExtents acad)
(vla-put-ActiveLayout acdoc aclay)
(princ)
(C:ZEA)
Jonathan3891
Why do you need a lisp to zoom extents in model space?
This can be easily added to your ACADDOC lisp which runs as soon as a drawing is open.
You could use something along the lines of this:
(command "tilemode" "1" "zoom" "extents")
Setting tilemode to 1 switches to model space.
If you wanted to zoom extents model space and switch back to paper space try this:
(command "tilemode" "1" "zoom" "extents" "tilemode" "0")
Jonathan Norton
Blog | Linkedin
paullimapa
Check out this example I found by googling "vla-ZoomExtents tilemode":
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vla-for-zoom-extents/td-p/2161297
In your case, instead of:
(vla-setvariable *doc* "tilemode" 0)
You'll want to set it to 1:
(vla-setvariable *doc* "tilemode" 1)
Then the following line of code will be invoked in model space only:
(vla-zoomextents *acad*)
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
