Run Audit command to all the files in one folder
Message 1 of 9
Hi
I want a lisp program to run Audit command for the files in one folder
And it should give the audit output of each file in csv format
like we do for single file by setting auditctl to 1,
I am not a programmer, kindly provide some help
Thank You
Replies (8)
Message 2 of 9
maratovich
AUDITCTL system variable is set to 1, a text file with an ADT file
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 9
yes i know, but i want to run audit on a batch of files together and create those text files with audit data
Thank You
Message 4 of 9
dbhunia
For Audit & Purge check this.......
http://forums.augi.com/showthread.php?60673-Purge-amp-Audit-all-drawing-files-in-a-folder
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 9
maratovich
Try this, maybe it will help:
www.kdmsoft.net
Message 6 of 9
Hi
Thanks a lot, it is working for, thanks for the solution,
Do u know LISP, Because i want to learn lisp - any suggestions from where i should start
Thank You
Message 7 of 9
dbhunia
Try this.....(with some modification in "DOFILE")
To Learn lisp I advice to go through online.......
Debashis Bhunia
Message 8 of 9
hi thanks a lot it is working,
But have one more problem, I have few files which has faulty objects
when I run audit, It will say as few items have passed and few items fail
For the items failing it will give the Cad handles as shown belowUntitled1.png
Is it not possible, when i run audit the adt file created should display only these faulty Object details as highlighted above
(i don't want the details of passing objects)
Message 9 of 9
dbhunia
Try this.......
For CSV file check in the selected folder with name "Report.csv"
Debashis Bhunia
